Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Compositing Transparent AOVs in AFTER EFFECT
0 REPLIES 0
Message 1 of 1
582 Views, 0 Replies
Hi!, I´m compositing classic AOVs in After effect by blending them with add mode, it works ok, but I noticed that transparency object get darker when I add more Passes, apparently the add blending mode does not work right with transparency. I rich a solution by applying the alpha channel to all passes at the same time on a precomp. It works, but i was wondering if this is the right workflow or there is another way to work with transparency on the AOVs passes.
Thanks!
Edu.
Labels (3)
0 REPLIES 0
