Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
How can I create a Height Map in Arnold 5?
2 REPLIES 2
giandosopaolo
1167 Views, 2 Replies
Hi
A question for the Arnold5 for Maya users:
Is there a way to create a Height Map (Substance Designer style) from a 3D model in a orthogonal view, like a AOV?
8 bit or 16 bit, similar to the "Grab Doc" command in Zbrush?
Many thanks
Paolo
Labels (4)
2 REPLIES 2
madsd
in reply to: giandosopaolo
You can do it in multiple ways.
- Z-Depth like you mention straigh up/down.
- Ramp over v channel and use as texture input on emission, this way you can also control the curve and the displacement texture can be scaled internally over the entire distance which is 0-1 where 1 is the top of the highest mountain.
giandosopaolo
in reply to: madsd
The second option seems the best. I hoped there was a "normalized" zdepth pass in 8 bit hidden somewhere but this is also very doable thanks :}
