I am having issues with my height map for my wood shader. I created textures in substance painter using relatively low values for height.
I tried two different node setups for height maps; however, both are producing extremely black, grainy renders.
For the second setup I tried to switch the 2dbump attribute from bump to tangent space normal to object space normal, however they all produced errors of areas rendering similarly or just failing to render.
