Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Cannot inspect ass file from HtoA?
9 REPLIES 9
Message 1 of 10
859 Views, 9 Replies
Hey there, I just imported my .ass file(simple sphere with a standerd shader on it and basic fur with hair shader on it) from houdini in to maya. And find that I cant inspect the Arnold file. Is this a know problem?
Tags (2)
Labels (2)
9 REPLIES 9
Message 2 of 10
Stephen.Blair
What do you mean by "inspect" ? The File Contents is empty?
Does standin appear in a render? Is there a bounding box in the viewport? Can you change the viewport drawing mode? Are there any errors in the script history or the Arnold log?
I've used ASS files from Houdini, in Maya, with no problems.
// Stephen Blair
// Arnold Renderer Support
Message 3 of 10
I don't mean viewport display, I mean inspect Arnold file. Normally this brings up a list of assets inside a stand-in.
Message 4 of 10
When I click the button, Nothing happens, like nothing. Even in the Script editor with echo on. Nothing happens. No error msg, nothing. It does render, and display and seems normal all except for "inspect arnold file". Is there something I'm missing here. Its all basic setups just a sphere and some fur and standard shaders unchaged...
Message 5 of 10
Stephen.Blair
It's the ####
Change that to an actual file, like "0013" and you should be able to inspect the file.
// Stephen Blair
Message 6 of 10
OMG, lol thats it. Okay then, so how do you edit it for the whole Sequence then.
Message 7 of 10
Stephen.Blair
An operator or override would apply on each ass file of the sequence. So if the same shape, shader, or light is in each ass file, you are ok.
// Stephen Blair
Message 8 of 10
cool thanks 😄
Message 9 of 10
Stephen.Blair
I'll open a ticket: Mtoa should be able to use the value in the Frame box to figure out what ass file to open
// Stephen Blair
Message 10 of 10
Thanks so much
