Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
displacement map is not working properly while rendering in arnold in maya
4 REPLIES 4
ravikanth7492
647 Views, 4 Replies
I have exported the displacement map from ZBrush to Maya. I used every necessary setting while exporting and importing it to Maya but still I am facing some detailing issues while rendering in Arnold, so can u pls help me out. I have also attached the screenshots of  Arnold, Zbrush, and the settings I have used while exporting and importing the displacement map from Zbrush to Maya.
4 REPLIES 4
lee_griggs
in reply to: ravikanth7492
Is it a 32-bit EXR? Are you using the RAW color space?
https://docs.arnoldrenderer.com/display/A5AFMUG/Maya+2017
Lee Griggs
Arnold rendering specialist
AUTODESK
ravikanth7492
in reply to: lee_griggs
hello, @lee_griggs thanks for responding. No, I didn't use the 32-bit exr map because it is bulging the mesh in Arnold while rendering so why  I had used the 16-bit 4k tiff displacement map. (I have attached the screenshot of the exr displacement map render image for better understanding.)
@lee_griggs  I'm getting a red color texture map while exporting the displacement map in 32-bit exr format from Zbrush.
Yes thats fine you need to connect the red channel in maya.
https://linktr.ee/cg_oglu
