Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
ACES Maya ignores texture import settings
26 REPLIES 26
Message 1 of 27
hyperviktor
1020 Views, 26 Replies
When I connect a texture map to aiStandard shader, no matter what I use as the input color space there is no effect in the render.
I have ACES 1.2 installed, OCIO config loaded etc. yet I still have a number of things that don't seem to work as expected.
Any help ?
Tags (1)
Labels (1)
26 REPLIES 26
Message 2 of 27
Chtenelis
in reply to: hyperviktor
You need to remake the tx file everytime you change the input colorspace.
Message 3 of 27
hyperviktor
For testing I don't use .tx files as takes ages to generate,I use the original .jpg with color profile assigned within aiImage and I have .tx generation turned off , although I did tests with .tx and didn't make any difference.
Message 4 of 27
lee_griggs
Hi Hyper, I presume you have the Color Space set to Utility - sRGB texture?
Once the .tx files are generated you should see speed improvements. Here are some of the benefits of using .tx files.
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 5 of 27
hyperviktor
in reply to: lee_griggs
Are you deliberately trying to be unhelpful ? We do use .tx textures in production and I'm well aware of the benefits , speed improvements etc. but in this case it's irrelevant.
My issue has nothing to do with .tx textures, I have a problem with ACES not doing what it should do. Do you have any comments on that ?
Message 6 of 27
Stephen.Blair
If you use a tx file for your test, then we can check it with oiiotool -v --info, and see what color conversion was applied. So...change the color space on the image node, render and the tx is updated, check the tx and see what color-convert was used.
// Stephen Blair
// Arnold Renderer Support
Message 7 of 27
lee_griggs
Render the shader ball scene here and if it doesn't match, upload the results.
Lee Griggs
AUTODESK
Message 8 of 27
hyperviktor
in reply to: Stephen.Blair
I'm using 'Utility - sRGB - Texture' for color inputs, 'Utility - Raw' for data.
My problem is that in my tests changing the texture's color space does not result a change in the render.
Message 9 of 27
hyperviktor
First thing I got was a warning that your OCIO cinfig is missing , but I'm using ACES 1.2 anyways so I guess I just point the project to that file.
Message 10 of 27
hyperviktor
Looks different, hre's the render and the converted .tx texture fileshaderball.jpgball.zip
Message 11 of 27
hyperviktor
Same problem - regardless what input color space I select in the aiImage, the render result stays the same.
Message 12 of 27
Stephen.Blair
Changing the color space on an aiImage forces an update of the tx, and the tx will have a different color-convert applied. You should see the maketx in the console log, the tx file should be updated, and the new tx used for the render (maybe you need to force update?)
// Stephen Blair
Message 13 of 27
hyperviktor
Nothing wrong with the .tx converter, I deleted the original .tx before rendering so it was generated during rendertime.
Message 14 of 27
hyperviktor
Here's what the imported .exr looks like in my hypershade editor.texture.jpg
Message 15 of 27
hyperviktor
Now it looks like this, pretty arbitrary but most importantly - without any changes.texture2.jpg
Message 16 of 27
Stephen.Blair
The Material Viewer doesn't update to the new tx when you change the Color Space, you have to pause and restart the material viewer.
I don't have that problem with Arnold Render View
// Stephen Blair
Message 17 of 27
hyperviktor
Again, I'm not using .tx for testing, I skip converting and I apply the color space rules to the texture. It shouldn't make any difference. If you look at the image you can see the texture is .exr
THIS IS THE PROBLEM : My render with ACES looks fucked up - why ?
Message 18 of 27
Stephen.Blair
I tested with exr, no tx. And same thing. I have to pause and restart the Material Viewer to see the update.
// Stephen Blair
Message 19 of 27
At least if you use tx, we can check the tx files to verify that the color conversion was applied.
// Stephen Blair
Message 20 of 27
hyperviktor
I did upload it 7 hours ago because you have asked - it's the ball.zip file as it doesn't let upload .exr files
Technology Administrators
