Arnold for Katana Forum
Rendering with Arnold in Katana using the KtoA plug-in.
DeepEXR in Katana
4 REPLIES 4
tim.goransson6XTRC
969 Views, 4 Replies
DeepEXR in Katana
I can't seem to get DeepEXR to work properly out of Katana, using the usual ArnoldOutputDefine(AOCD) + RenderOutputDefine(ROD) combo.
On the AOCD, the name, layerName, and channel, I've all named "deep". I've set the "type" to "INT".
On the ROD, "outputName" is "deep", "colorspace" is "raw", "channel" is "deep", and the fileExtension is "exr".
The render finishes fine, and the filesize is pretty big, like you'd expect, but when I bring it into Nuke, I get a "no deep data found in file" error.
Any help is appreciated!
Thank you.
Tags (2)
Labels (2)
4 REPLIES 4
Are you rendering tiled? Try scanline
// Stephen Blair
// Arnold Renderer Support
I've tried both tiled and scanline, both giving me the same result
Here's a simple test scene. Does that work?
aov_deep.katana.txt
// Stephen Blair
This did the trick! Thank you. I was missing a couple of options, like changing the driver to be "driver_deepexr"
Technology Administrators
