Solaris - Displacement not working (Kicking a USD file)
am_wilkins
Message 1 of 10
am_wilkins
In this test scene, I have two shaders assigned to two halves of a sphere.
One half has a green shader with a "Cell Noise" displacement which works locally in the Arnold render delegate.
However, when I export this scene as USD and Kick it - the displacement no longer works.
I tired to add the "Render Geometry Settings" node to ensure the Arnold displacement settings are there, but that made no difference.
Houdini local render:
Kick output:
Is there something I'm missing here with Kick? Or how to translate these displacement settings to USD / Kick?
All the best,
Andrew
HtoA: 6.2.1.0
Arnold: 7.2.1.0
Houdini: 19.5.534 Py3.9
Replies (9)
Message 2 of 10
Stephen.Blair
Works for me. But I don't see the subdivision in the Solaris viewport, only in the kick display.
Can you upload your test scene?
// Stephen Blair
// Arnold Renderer Support
Message 3 of 10
am_wilkins
Hi Stephen,
Thanks for the reply.
Yeah, I can send the USD file through to the arnoldrenderer support email. If that's okay?
Will do that now.
Andrew
Message 4 of 10
Stephen.Blair
Using the Component Builder (instead of doing it manually), I get no displacement.
Because USD Rop is saving the geo with
            uniform token subdivisionScheme = "none"
If I remove that from the geo usda file, then I get the displacement.
So it may be some flag on the component nodes that  control this...
// Stephen Blair
Message 5 of 10
Stephen.Blair
Ah, Treat Polygons as Subdivision Surfaces on the Component Geometry LOP
// Stephen Blair
Message 6 of 10
am_wilkins
Interesting, thanks Stephen
If I enable the "Treat Polygons as Subdivision Surfaces" this does then put info into the subdivion scheme.
Render result in Houdini Arnold render delegate appears the same... however when I Kick it—the displacement still isn't working for me.
I can see the setting in the USD file:
All the best,
Andrew
Message 7 of 10
Stephen.Blair
Probably something do with this:
Warning: in SdfPath at line 151 of S:\gocd\pipelines\kook\kook\usd\build\usd-22.11_windows-x86_64_static_vc-14.3_cxx14\pxr\usd\sdf\path.cpp -- Ill-formed SdfPath <NULL /componentoutput1/mtl/green_mb/cell_noise1>: syntax error
// Stephen Blair
Message 8 of 10
am_wilkins
Do you have any idea what that means?
I rebuilt the test scene without the component builder. Just a simple sphere with shaders assigned (which I can send you again) but I'm getting the exact same issue where displacement won't render with Kick.
Andrew
Message 9 of 10
Stephen.Blair
Looks like a bug to me, so I logged it here:
// Stephen Blair
Message 10 of 10
am_wilkins
Okay, thanks Stephen!
