Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Arnold keeps crashing with error message "Bad Modules Crash"
25 REPLIES 25
Message 1 of 26
ruisun88
2747 Views, 25 Replies
Hello, I'm encountering an error when rendering to disk with Arnold.
I'd launch the render and for a while it'd be rendering properly, and a few frames into it, it'll error with this message:
Bad Modules Crash
SymInitialize returned error: 87
I've created a simplified scene that reproduces this error reliably on my machine.
Can someone offer an explanation on what might have gone wrong?  Maybe I clicked on something I shouldn't have?
Attaching some screen shots.
CPU: Threadripper 3970X
GPU: RTX 3090
25 REPLIES 25
Message 2 of 26
ruisun88
in reply to: ruisun88
I reached a limit on attachments on my original post, so attaching the simplified hip file here.
Also attaching a GIF of the error happening.
Message 3 of 26
ruisun88
It doesn't produce the error on any specific frame, it appears randomly.
Message 4 of 26
JohnDraisey
Funny, we're getting an Error 87 in Houdini (while using HtoA) on a Threadripper PC as well. Submitted the issue to SideFX first. Also running a memory test on the PC.
Message 5 of 26
am_wilkins
Hi everyone,
We've also getting the same error.
Error in this log file (285): stderr: syminitialize returned error: 87
Has anyone heard back from either SideFX or Arnold regarding this error?
Or has any ideas as to the cause?
all the best,
amwilkins
Houdini Core Version 19.5.569
Arnold Core: 7.2.2.0
HotA: 6.2.2.0
CPU: AMD Ryzen TR 3990x
RAM: 128GB
GPU: NVIDIA RTX A4000
OS: Windows
Message 6 of 26
Stephen.Blair
in reply to: am_wilkins
I was able to reproduce this when I rendered with GPU. Not CPU.
When I use GPU, the hick process isn't ended when the frame is finished, so I render 17 frames I have 17 hick processes still running, and I think that's what causes the crash.
// Stephen Blair
// Arnold Renderer Support
Message 7 of 26
a.babak
Our artists also complain on these crash-errors. Even when not rendering. The common thing is Threadripper PCs.
Message 8 of 26
Stephen.Blair
in reply to: a.babak
Another recently reported issue is that some OSL (with errors in the code) can cause this.
Do you have a way to repro the crash-error?
Who is "our"? Aristocrat Leisure Ltd ?
// Stephen Blair
Message 9 of 26
a.babak
in reply to: Stephen.Blair
No repro case yet, unfortunately. Still trying to figure out the conditions. Our team is Plarium.
Message 10 of 26
howardHZL6N
In Houdini, getting this 87 error when simply trying to RENAME nodes and or copy paste nodes!?!?
Message 11 of 26
adlabac
unfortunately we came across this error too, no gpu rendering. Several different scenes has this problem where this error randomly happens when user renders scene. I can provide one repro scene which fails every time when you try to render it. I've tried it with vanilla Houdini only with Arnold plug.
Message 12 of 26
changdongwong
I meet the same error....
Message 13 of 26
sarachris2
maybe I think I've solved it. (at least in my case)
I also had the same problems with only render gpu (RTX 4090) with random stop in rendering
disabling in the USD ROP RENDER the default snapshot interval (set to 300 of default)
I was able to finish test sequences that were previously skipping and crashing.
random solution to a random problem 😁
Message 14 of 26
fguiliani_vfx1
We met the same error 87, since we updated Houdini to 19.5
Someone has found an explanation or a solution ?
Message 15 of 26
Error 87 means only that a crash happened. It's not specific to any one thing. The crash could be anything.
Do have a scene that reproduces the crash? Ideally as simple a scene as possible.
// Stephen Blair
Message 16 of 26
howardHZL6N
happens on copy pasting, renaming nodes, saving through SG....simple stuff!
all googling points to Arnold, even though were not even rendering anything?!
driving US MAD! 😞
Message 17 of 26
am_wilkins
Houdini 20.0.590 and Arnold update appears to have helped, however I'm unfortunately still now get a "Fatal Error" every 10mins IPR rendering with Arnold compared to Karma even on very simple test assets.
In HtoA 6.2.5.1 there was this in the comments:
  • HTOA-2446 - Avoid "SymInitialize returned error: 87" pop-up messages for crashes on Windows
Houdini Core Version 20.0.590
Arnold Core: 7.2.5.1
HotA: 6.2.5.1
RAM: 128GB
OS: Windows
Message 18 of 26
a.babak
The release note wording is unclear. Was the crash reason fixed, or does it still occur without a popup?
Message 19 of 26
Stephen.Blair
You won't see the pop-up "SymInitialize returned error: 87" when there is a crash. That's all. if there's a crash, it will still crash, you just won't see that error 87 message.
Before this fix, any crash for almost any reason would also trigger the pop up message.
// Stephen Blair
Message 20 of 26
Stephen.Blair
HotA: 6.2.5.1
RAM: 128GB
OS: Windows
With any scene, no matter how simple? I haven't seen that myself.
The error 87 popup happened with any type of crash and really had nothing to do with why the scene crashed. The crash could be caused by any number of reasons.
// Stephen Blair
