Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Solaris - Custom AOV not working
32 REPLIES 32
Message 1 of 33
am_wilkins
1464 Views, 32 Replies
Hi there,
Using this method below—to create light group, it was working last year.
However, now it isn't working anymore and unless I've made a mistake... appears to broken.
The AOV registering correctly along side the other built-in AOV.
Same setup here as I've used before.
Light Group tag.
On starting the render, the light group doesn't appear.
I've had the same issue with another custom AOV I was trying to create based on a shader.
thanks,
amwilkins
Houdini Core Version 20.0.590
Arnold Core: 7.2.5.2
HotA: 6.2.5.2
CPU: AMD Ryzen TR 3990x
RAM: 128GB
GPU: NVIDIA RTX A4000
OS: Windows
32 REPLIES 32
Message 2 of 33
Stephen.Blair
in reply to: am_wilkins
When I tested this in January
...for the RGBA light group render vars, I had to use the actual LPE C.*.<L.'blue'>
But for other AOVs, like direct and indirect, I was able to use direct_blue
// Stephen Blair
// Arnold Renderer Support
Message 3 of 33
am_wilkins
in reply to: Stephen.Blair
Hi Stephen,
I tried using the LPE too, which also didn't work.
As well as "direct_key" just for some quick testing, but no dice.
thanks,
amwilkins
Message 4 of 33
Stephen.Blair
I just opened up my test scene from Jan, in the latest HtoA, and it's working for me.
// Stephen Blair
Message 5 of 33
rachid_1
work fine here
try this scene
Tags (1)
Message 6 of 33
am_wilkins
in reply to: rachid_1
Hi Rachid,
Thanks so much for this file.
It's helped me see that it's likely the "Arnold Render Settings" HDA node causing the issue.
I was using this HDA last year in combination with light groups but now it appears not working. I guess it's time I abandon using it.
Your scene working out the box 👍
Swapped out to a "Arnold Render Settings" instantly not working, while even all the AOV still are added to the scene graph in the same place.
@Stephen.Blair Can you repro on your end?
+1 request for a round of fixes and adjustments on this HDA please. Ability to add custom AOV etc.
All the best,
amwilkins
Message 7 of 33
Stephen.Blair
You can't use the Arnold Cryptomatte AOVs LOP together with Arnold Render Settings LOP. The Arnold Render Settings LOP by itself works fine for me.
// Stephen Blair
Message 8 of 33
am_wilkins
Hi Stephen,
Bypassing the Crytomatte node, still not working.
amwilkins
Message 9 of 33
Stephen.Blair
You have to use the Arnold product type, that's for sure.
// Stephen Blair
Message 10 of 33
am_wilkins
  1. Opened the scene above from Rachid
  2. Checked LightGroup AOV are working with manual Render Product and Render settings. They are working.
  3. Dropped down a new "Arnold Render Settings" HDA, switched to this. AOV don't work.
  4. Enabled "Arnold Render Product". AOV still don't work.
AOV are all registered withing the same place on the scene graph. They should be working.
Have you tried using this scene file linked above?
Additionally, I opened an older scene of mine from Aug 2023. The AOV are working in that scene, exactly how things are setup here. However, as soon as I drop down a new Arnold Render Settings node—they no longer work. (Due to the Arnold Render Settings node getting updated to the latest as soon as I do that.)
amwilkins
Message 11 of 33
Hi guys,
this is what happen when I render arnold_sick
Message 12 of 33
am_wilkins
Just adding to this, likewise the "Arnold Imagers" which I guess count as a custom shader on the Arnold Render Settings node—doesn't currently work either.
It's worth noting that they work when using the seperate Render Product + Render Settings nodes rather than the Arnold HDA.
Any updates from the Arnold team?
Are you able to reproduce using the scene from Rachid in this thread?
amwilkins
Message 13 of 33
Stephen.Blair
amwilkins
It all works for me. Do you have a scene from your studio that doesn't work?
// Stephen Blair
Message 14 of 33
am_wilkins
I can make one, thought I wouldn't need to since it's reproduce-able with that scene posted above from Rachid.
Interesting that it's working for you... all I did was drop down a new Arnold Render Settings HDA and it breaks the AOV instantly.
Will get back with a scene, once I've made one.
amwilkins
Message 15 of 33
Stephen.Blair
Ok. I see your problem.
You cannot use Arnold Render Settings if you're setting up custom AOVs and your own Render Product LOPs. I logged that limitation awhile ago.
// Stephen Blair
Message 16 of 33
am_wilkins
Great.
Not sure when you logged that limitation..
Custom "Render Var" (for lightgroup) in combination with the Arnold Render Settings HDA was possible last year in these versions:
Houdini Core Version 19.5.682
Arnold Core: 7.2.3.1
HotA: 6.2.3.1
I will still probably finish setting up a repro scene anyways, as I think there is likely more problems to illustrate.
Message 17 of 33
Stephen.Blair
August or so. I don't know how it could have worked, because we end up with multiple render products and the render settings uses just one of them.
In the current HtoA, I had to edit the Render Settings
// Stephen Blair
Message 18 of 33
am_wilkins
Oh sorry, I don't think we're on the same page.
I've been talking about "Render Var" in combination with a Render Product or a Arnold Render Settings (which contains a render product). So only one product.
I haven't yet needed two render products, thankfully.
Message 19 of 33
rachid_1
Yes it doesn't work because both arnold_rendersettings & arnold_rendervars doesn't yet support custom aov, while all other renderers DCC do!
So we can't use custom aov when using arnold_rendervars or arnold_rendersettings
and rendervar is deprectaed!
So what's the point to have both arnold_rendersettings & arnold_rendervars witout custom aov???
unfortunately, Arnold in Houdini is delivered as a soldier who goes to war on a crutch! and they always talk about priority!
Message 20 of 33
Stephen.Blair
I think this is similar, I have to edit the Render Product from the Arnold Render Settings to include the other render vars...still to be confirmed...
// Stephen Blair
