Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Solaris - Custom AOV not working
32 REPLIES 32
Message 1 of 33
am_wilkins
589 Views, 32 Replies
Hi there,
Using this method below—to create light group, it was working last year.
However, now it isn't working anymore and unless I've made a mistake... appears to broken.
The AOV registering correctly along side the other built-in AOV.
Same setup here as I've used before.
Light Group tag.
On starting the render, the light group doesn't appear.
I've had the same issue with another custom AOV I was trying to create based on a shader.
thanks,
amwilkins
Houdini Core Version 20.0.590
Arnold Core: 7.2.5.2
HotA: 6.2.5.2
CPU: AMD Ryzen TR 3990x
RAM: 128GB
GPU: NVIDIA RTX A4000
OS: Windows
32 REPLIES 32
Message 21 of 33
am_wilkins
in reply to: Stephen.Blair
Okay cool, let me know how it goes.
I started setting up a repro scene, I can't double check the EXR output right now...however, I've checked in scene rendering in the viewport/hydra and confirmed a few issues.
I wanted to get this scene to you so long (see attached) but I also might be able to check and expand on it later to resend.
Ideally all options below are also render tested using Husk & Kick/Sick, to confirm the EXR result is also the same between these render options.
(The other issues we've spoken about Arnold HDA making "RGBA" instead of "rgba", EXR channels not working correctly with Husk, etc. etc.)
Example 01:
Example 02:
Example 03:
Example 04:
all the best,
amwilkins
Message 22 of 33
am_wilkins
in reply to: am_wilkins
A discovered a likely related but somewhat new problem.
I was moving forward with the "manual" setup with product set to "raster" as this was producing results locally and rendering on our farm through Husk.
AOV added manually one-by-one instead of /Render/Products/Vars/* - As this seems to break the AOV.
(Receiving AOV locally and through Husk - built-in and light groups)
However, once I "matte" the environment/set objects, then the AOV while still working locally—don't work when rendering through Husk. (Arnold CPU)
Locally = Everything working:
Sam as above.
When objects are matted—from the Husk render, viewing the EXR in Nuke:
No AOV are present in the EXR.
If I render the "Beauty" ie. no objects are matted. Then the AOV are working and present in the EXR.
Only difference is the matting.
Not sure is this is related to this problem with the Arnold GPU:
https://forums.autodesk.com/t5/arnold-for-houdini-forum/indirect-light-not-working-on-arnold-gpu-whe...
However this is on the CPU.
amwilkins
Message 23 of 33
am_wilkins
@Stephen.Blair Updated the "repro scene" here.
  • Added a new "test06_manual_product_raster_matte" to re-present the issue with "matting" and then AOV not working.
I can send through the Husk render results that I get, but the file size is too big for these forums.
Let me know if you can re-produce on your side.
These issues would be great to see solved. HotA isn't seeming very production ready atm.
amwilkins
Message 24 of 33
Stephen.Blair
amwilkins
Hi
test01_manual_product_arnold
AOVs missing from viewport Render Outputs list
We had the same problem with Arnold Render Settings LOP, and we had to add some code to set a Hydra flag.
In your scene, I added a Python Script LOP, and added this to it:
from pxr import Sdf
prim = stage.GetPrimAtPath("/Render/Products/renderproduct_arnold")
attr = prim.CreateAttribute("includeAovs", Sdf.ValueTypeNames.Bool)
attr.Set(True)
Then the AOVs showed up in the Render Output lists, and they were there in the rendered file (the one from the Render Product > Name)
Logged as HTOA-2586 "No AOVs with arnold product type and Render Settings LOP"
Note that the USD Render ROP > Override Output Image does not override (you still get the image from the Render Product), and the "override" image is missing AOVs.  This is a known issue, logged as HTOA-2583
"Override Output Image does not override and does not include AOVs"
// Stephen Blair
// Arnold Renderer Support
Message 25 of 33
For test02_manual_product_raster, all the AOVs were there when I rendered to disk with husk.
// Stephen Blair
Message 26 of 33
test03_arnoldHDA_product_raster
Using Render Vars with Arnold Render Settings LOP
Arnold Render Settings doesn't include the Render Vars, just the AOVs that you add in the Arnold Render Settings > File Output > AOVs tab.
  • I used the Arnold Render Settings for the AOVs like diffuse_direct.
  • Then I edited the Ordered Vars property and added the light group Render Vars
Then all the AOVs showed up in the viewport list of Render Outputs.
Update: Logged as
HTOA-2587 Cannot use Render VAR LOPs with Arnold Render Settings LOP
// Stephen Blair
Message 27 of 33
Stephen.Blair
For the output suffix, it seems to work with Direct USD Render only.
ARNOLD-13549
output_suffix parameter does not work with OIDN denoiser
// Stephen Blair
Message 28 of 33
am_wilkins
Good day @Stephen.Blair
Okay thanks for the replies, glad to see you can reproduce the issues on your end. 👍🏻
Last one is just that "matting + no aov", is that logged as an issue?
Hopefully there can be some fixes in the next update or two for HotA.
all the best,
amwilkins
Message 29 of 33
Stephen.Blair
all the best,
amwilkins
Hi
The matte one works ok for me. In the Solaris viewport, and a rendered EXR, I see all the AOVs and they look right.
// Stephen Blair
Message 30 of 33
am_wilkins
Hi Stephen,
It works locally, but not with a Husk render.
Did you try that?
Thanks.
Message 31 of 33
Stephen.Blair
@am_wilkins wrote:
Hi Stephen,
Did you try that?
Thanks.
Yes, that was the rendered EXR that I checked. I used the USD Render ROP with husk
// Stephen Blair
Message 32 of 33
am_wilkins
Thanks for checking. 👍
I did a command-line render on the USD with Husk locally, and it's working now. (AOV are there)
Previously it was through our render farm submitter.
Doing another render on our farm also with Husk isn't working (no AOV), but now at least we know that's something on our end.
If the cause is something worth mentioning, I'll update here.
At least that's one we can scratch off the list for now!
Thank you
amwilkins
Message 33 of 33
Stephen.Blair
If the cause is something worth mentioned, I'll update here.
Thank you
amwilkins
Maybe you can compare the usda from the farm with a local usda?
// Stephen Blair
