Solaris Arnold does not output metadata
masiKBS7P
Message 1 of 16
masiKBS7P
Hi everyone,
I am trying to get the same metadata on the rendered EXRs that Arnold Maya is writing out for example, at the moment only standard metadata are available but none of the Arnold specifics are there... like the diffuse_samples or memory peak info. Do you know if there is any way to write them ?
Thanks a lot.
Cheers and have a nice day,
Matt
Replies (15)
Message 2 of 16
Stephen.Blair
If you're using husk to render, then no.
If you're using HtoA 6.1.1 or later, you could use the Solaris version of kick to render:
Or write out usd files and then use kick itself.
// Stephen Blair
// Arnold Renderer Support
Message 3 of 16
masiKBS7P
Hi Stephen,
Thank you I will try to use the kick instead of husk ! 🙂
Best regards and have a nice day,
Matt
Message 4 of 16
Stephen.Blair
Actually, it's not fully exposed yet in Houdini.
We don't ship a LOP that uses it yet.  You would have to change the USD render ROP to usd the arnold render delegate and then change the render command to sick.
// Stephen Blair
Message 5 of 16
david.ostler2WSX9
You can find info on writing metadata to your husk/anrold exr files here:
https://www.sidefx.com/forum/topic/75992/
Message 6 of 16
david.ostler2WSX9
Hey Stephen,
This is the only mention of sick I can find anywhere in the forums or docs.  What exactly is it and now does it differ from kick?
Message 7 of 16
Stephen.Blair
@david.ostler2WSX9 wrote:
Hey Stephen,
You would use sick in Solaris instead of husk.
// Stephen Blair
Message 8 of 16
bogdan.amidzic
1. What would be benefits of sick over husk?
2. Would it work on render farm manager like deadline?
3. Does it finally render out cryptomatte passes?
4. If I add variance aov in my render var list, could these exr files be denoised with noice.exe. This is currently very urgent problem for me.
Message 9 of 16
Stephen.Blair
The advantage is that you're not going through Hydra to render with USD. That's a side trip that just complicates everything. Rendering USD with kick is better than husk, but you can't use kick from a USD Render ROP so we will add sick for that.
You can already render cryptomatte passes with kick. sick will do that too.
sick like kick is directly rendering with Arnold, not going through Hydra, so you'll get the right metadata.
// Stephen Blair
Message 10 of 16
bogdan.amidzic
Thanks for fast answer. I'll try it.
Message 11 of 16
bogdan.amidzic
It seems like it is working. One problem I'm facing is that sick can't create directories for render vars, but that might be some folder permissions. Other problem is that image rendered in solaris and rendered via sick have like 1000 times brightness difference. Attached are these examples:
Message 12 of 16
bogdan.amidzic
Reply above should have been to you Stephen.
Thanks!
Message 13 of 16
Stephen.Blair
New HtoA just out...includes
  • Cryptomatte in Solaris : Cryptomatte is now supported in Solaris, including with husk renders. A new LOP Arnold Cryptomatte AOVs allows to setup the render vars needed for cryptomatte (HTOA-2011)
https://docs.arnoldrenderer.com/display/A5AFHUG/HtoA+6.1.3.0
// Stephen Blair
Message 14 of 16
masiKBS7P
Thanks everyone for the kick and sick info.
I have tried with sick for the metadata and cryptomatte, everything seems to be working but even when I write 5 frames it does only render 1 and stops.
For example the command is : ./sick -i 'filepath'.usd
Do we need to add extra flags, even if we specified the range in solaris usd rop ?
Thank you !
Message 15 of 16
Stephen.Blair
Thank you !
If you're using the command line, you might as well use kick.
sick is meant mostly to replace husk in Solaris.
sick, like kick, is one frame at a time.
You can run sick -h to see the list of options
// Stephen Blair
Message 16 of 16
pauldonsw
With sick, is it possible to pass custom metadata values to exr? The following works with husk but not sick, is it expecting a different attribute?
renderproduct.CreateAttribute("driver:parameters:OpenEXR:My_Value", Sdf.ValueTypeNames.String)
