Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Hython no Platform Plugin found
9 REPLIES 9
Message 1 of 10
194 Views, 9 Replies
Hey,
so when i want to render from commandline with Arnold via hython (or Deadline) i get the attached popup. I tried to the solution proposed here, for copying the qwindows.dll a level higher already, which didn't help. I also tried an older version for the license manager and removing all other plugins/packages from houdini.
The command used would be something like this:
cd C:/PROGRA~1/SIDEEF~1/HOUDIN~1.622\bin
hython hrender.py -e -f 1000 1250 -i 1 -d /out/arnold1 "C:/Users/Elmar/Desktop/Arnold.hiplc"
Rendering via a Houdini-Gui Session works just fine. Any ideas on how to solve this, or is anyone able to reproduce this issue?
Edit:
Versions: Houdini 19.0.622-py3 and HtoA 6.1.2.0
9 REPLIES 9
Message 2 of 10
Stephen.Blair
Did you reinstall the Autodesk Licensing Service, and AdSSO?
// Stephen Blair
// Arnold Renderer Support
Message 3 of 10
in reply to: Stephen.Blair
Yes i did. The license is shown as correct when accessed via the menu in Houdini/LicenseManager. In Commandline mode it complains as seen below.
0:00:00   100MB         | [hick] Received: AA: 3 3
00:00:00   100MB         | [hick] Received: begin
00:00:00   100MB         | [hick] Batch mode
00:00:00   100MB         | log started Tue May 31 19:46:07 2022
00:00:00   100MB         | Arnold 7.1.2.0 [a68d7fc3] windows clang-10.0.1 oiio-2.4.0 osl-1.12.0 vdb-7.1.1 adlsdk-6.3.1.44 clmhub-2.0.0.235 rlm-14.1.3 optix-6.6.0 2022/05/19 13:17:09
00:00:00   100MB         | running on MOTHER, pid=15640
00:00:00   100MB         |  1 x AMD Ryzen Threadripper 1950X 16-Core Processor  (16 cores, 32 logical) with 130949MB
00:00:00   100MB         |  NVIDIA driver version 512.96 (Optix 60802)
00:00:00   100MB         |  GPU 0: NVIDIA GeForce RTX 2080 @ 1710MHz (compute 7.5) with 8191MB (7654MB available) (NVLink:1)
00:00:00   100MB         |  GPU 1: NVIDIA GeForce RTX 2080 @ 1710MHz (compute 7.5) with 8191MB (7654MB available) (NVLink:1)
00:00:00   100MB         |  Windows 10 (version 10.0, build 19044)
00:00:00   100MB         |  soft limit for open files changed from 512 to 2048
00:00:00   100MB         |
00:00:00   100MB         | [metadata] loading metadata file: C:\Users\Elmar\htoa\htoa-6.1.2.0_re046489_houdini-19.0.622.py3\htoa-6.1.2.0_re046489_houdini-19.0.622.py3\scripts\bin\arnold.mtd
00:00:00   117MB         | [color_manager_ocio] default ocio.config found in C:\Users\Elmar\htoa\htoa-6.1.2.0_re046489_houdini-19.0.622.py3\htoa-6.1.2.0_re046489_houdini-19.0.622.py3\scripts\bin\../ocio/configs/arnold/config.ocio
00:00:00   117MB         | loading plugins from C:\Users\Elmar\htoa\htoa-6.1.2.0_re046489_houdini-19.0.622.py3\htoa-6.1.2.0_re046489_houdini-19.0.622.py3\scripts\bin\..\plugins ...
00:00:00   117MB         |  alembic_proc.dll: alembic uses Arnold 7.1.2.0
00:00:00   117MB         |  [metadata] loading metadata file: C:\Users\Elmar\htoa\htoa-6.1.2.0_re046489_houdini-19.0.622.py3\htoa-6.1.2.0_re046489_houdini-19.0.622.py3\scripts\bin\..\plugins\alembic_proc.mtd
00:00:00   117MB         |  cryptomatte.dll: cryptomatte uses Arnold 7.1.2.0
00:00:00   117MB         |  cryptomatte.dll: cryptomatte_filter uses Arnold 7.1.2.0
00:00:00   117MB         |  cryptomatte.dll: cryptomatte_manifest_driver uses Arnold 7.1.2.0
00:00:00   117MB         |  [metadata] loading metadata file: C:\Users\Elmar\htoa\htoa-6.1.2.0_re046489_houdini-19.0.622.py3\htoa-6.1.2.0_re046489_houdini-19.0.622.py3\scripts\bin\..\plugins\cryptomatte.mtd
00:00:00   117MB         |  htoa_mandelbulb_proc.dll: mandelbulb uses Arnold 7.1.2.0
00:00:00   118MB         |  [metadata] loading metadata file: C:\Users\Elmar\htoa\htoa-6.1.2.0_re046489_houdini-19.0.622.py3\htoa-6.1.2.0_re046489_houdini-19.0.622.py3\scripts\bin\..\plugins\htoa_mandelbulb_proc.mtd
00:00:00   122MB         |  usd_proc.dll: usd uses Arnold 7.1.2.0
00:00:00   122MB         |  [metadata] loading metadata file: C:\Users\Elmar\htoa\htoa-6.1.2.0_re046489_houdini-19.0.622.py3\htoa-6.1.2.0_re046489_houdini-19.0.622.py3\scripts\bin\..\plugins\usd_proc.mtd
00:00:00   122MB         | loaded 6 plugins from 4 lib(s) in 0:00.09
00:00:00   131MB         | [color_manager_ocio] default ocio.config found in C:\Users\Elmar\htoa\htoa-6.1.2.0_re046489_houdini-19.0.622.py3\htoa-6.1.2.0_re046489_houdini-19.0.622.py3\scripts\bin\../ocio/configs/arnold/config.ocio
00:00:00   141MB         | [hick] Start
00:00:00   141MB         | [hick] Received: log_verbosity: 7942
00:00:00   141MB         | [hick] Received: log_console_enable: 1
00:00:00   141MB         | [hick] Received: log_file:
00:00:00   141MB         | [hick] Received: log_max_warnings: 5
00:00:00   141MB         | [hick] Received: delta_publisher_port: 52453
00:00:00   141MB         | [hick] Received: threads: 0
00:00:00   141MB         | [hick] Received: assfile: c:\users\elmar\appdata\local\temp\houdini_temp\htoa_Elmar\14136_aa96f171-a10b-4bc3-ae8f-cb84d186b315.ass
00:00:00   145MB         | [metadata] loading metadata file: c:\users\elmar\appdata\local\temp\houdini_temp\htoa_Elmar\14136_aa96f171-a10b-4bc3-ae8f-cb84d186b315.ass
00:00:00   146MB         | [ass] loading c:\users\elmar\appdata\local\temp\houdini_temp\htoa_Elmar\14136_aa96f171-a10b-4bc3-ae8f-cb84d186b315.ass ...
00:00:00   180MB         | [ass] read 33631653 bytes, 8 nodes in 0:00.04
00:00:30   185MB WARNING | rendering with watermarks because of failed authorization:
00:00:30   185MB         |  [clm.v2] timeout before callback was called
00:00:30   185MB         |  environment variables:
00:00:30   185MB         |         ARNOLD_LICENSE_ORDER   = (not set)
00:00:30   185MB         |         ARNOLD_LICENSE_MANAGER = (not set)
00:00:30   185MB         |  [rlm]  solidangle_LICENSE     = (not set)
00:00:30   185MB         |  [rlm]  RLM_LICENSE            = (not set)
00:00:30   185MB         |  [clm]  ADSKFLEX_LICENSE_FILE  = (not set)
00:00:30   185MB         |  [clm]  LM_LICENSE_FILE        = (not set)
The popup posted appears before the warning about watermarks. Rendering without watermarks is just fine in a GUI-Session.
Message 4 of 10
Stephen.Blair
You could get Process Monitor logs, one for a working license check out, and one for a failure, and compare what AdskLicensingAgent is doing.
Otherwise, you'll have to contact Autodesk support (via manage.autodesk.com) for this AdskLicensingAgent problem. That Agent is part of the common Autodesk licensing platform.
// Stephen Blair
Message 5 of 10
Ok. Thanks for the quick replies anyways. I'll contact them then.
Message 6 of 10
A Process Monitor log will show where the AdskLicensingAgent is looking for Qt plugins
// Stephen Blair
Message 7 of 10
From what i can see it is looking in the correct spot. Full Logfile attached. Both, Houdini and Arnold are once again clean re-installations now also.
Message 8 of 10
Stephen.Blair
Could be this:
// Stephen Blair
Message 9 of 10
Ok. Do you have a suggestion on how to solve this then? This is a vanilla Houdini Installation and I am really not sure how to proceed with this. Thank you.
Message 10 of 10
Stephen.Blair
Possibly with QT_PLUGIN_PATH?
Prepend the AdskLicensingAgent QT path to that.
When AdskLicensingAgent starts, the environment has this:
QT_PLUGIN_PATH=C:/PROGRA~1/SIDEEF~1/HOUDIN~1.622/bin/Qt_plugins
That's the only QT thing I see in the environment.
The other thing to do is compare the environment under hython versus under Houdini
// Stephen Blair
