Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
make_texture ERROR: Could not rename file: Access is denied
1 REPLY 1
Johanalv
912 Views, 1 Reply
Johanalv
Hello, I am having this issue in htoa(latest version) where whenever I select Arnold > update tx textures , it gives me this error, from the log looks like a permission issue to rename the file, but no idea how to solve it. This happens after I render for the first time, if for example I change the color space or update a file from substance painter and try to update the tx file. Any ideas? Thank you
errorerror
errorerror
Tags (3)
1 REPLY 1
supervisorAlone
in reply to: Johanalv
supervisorAlone
I've the same problem,
in addition i also have this problem:
[texturesys] unable to convert from color space "Utility - Raw", ignoring color transform
This issue also occurs for others color profile in texture section  although ocio config is loaded correctly.
Thankyou for support
