Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Arnold fails to render complex volumes
0 REPLIES 0
Message 1 of 1
adminBKGWX
180 Views, 0 Replies
If a pyro sim is low to medium resolution it will render the volume, but there seems to be a file size or detail threshold to which Arnold stops being able to process the volume. I know it’s not a problem with the cache because if I render the same cache in mantra its read and renders without issue. Also the volume can be seen in the viewport Arnold just refuses to render. Again if I make the sim lower resolution Arnold will render it fine. Anyone ever seen this before?
0 REPLIES 0
