Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
I can't apply two textures to one object.
1 REPLY 1
amielniczuk01
186 Views, 1 Reply
My problem is that I have an object, let's say it's a chair, and I can't apply two Arnold material builder textures to different parts of that object even though they have separate UV groups.
[polymesh] /obj/krzeso/polygons: out-of-range shader
430MB WARNING | Aborted by user: received abort signal
Labels (2)
1 REPLY 1
peterDTE7K
in reply to: amielniczuk01
in OBJ level you can apply only single material per object. If you need multiple you can do it in SOP level. Assign group to primitives where you need material 1 and apply material 1 to that group, repeat for group 2.
