Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
How to set up Arnold for Houdini render farm ?
2 REPLIES 2
anh.bochoangbao
398 Views, 2 Replies
Hello everyone, when set up a render farm with Arnold using Houdini, do we need a Houdini engine license for every single render node? Or using a third party to run Htoa on each render node (Ex: Backburner when using Maya, 3ds Max)?
Please help me. Thank you!!!
Tags (1)
Labels (1)
2 REPLIES 2
You need an Arnold license for each render node.
You don't need a Maya or 3ds Max license.
If you use kick, you don't need anything except the Arnold license.
If you use Houdini, I think you need some kind of Houdini license. Check with Side Effects if you're not sure.
// Stephen Blair
// Arnold Renderer Support
Thanks for your updates!
