Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Shader network gone in Houdini after opening file in 18.5.696
5 REPLIES 5
eddi_fuhrmann
272 Views, 5 Replies
Hello.
When i open my files with the shaders they are all gone and i get this errors in the console...
i know it has something to do with the houdini path but i am not sure whre exactly the problem is.-.
this is the current state of my houdini env. file
# Example:
# HOUDINI_NO_SPLASH = 1
# htoa config start
PATH = "$PATH;C:/Users/eddi_/htoa/htoa-5.6.3.1_reef1df0_houdini-18.5.696.py3/htoa-5.6.3.1_reef1df0_houdini-${HOUDINI_VERSION}.py3./scripts/bin"
HOUDINI_PATH = "C:/Users/eddi_/htoa/htoa-5.6.3.1_reef1df0_houdini-18.5.696.py3/htoa-5.6.3.1_reef1df0_houdini-${HOUDINI_VERSION}.py3;&"
# htoa config end
would be cool if some one can help me because this causing real problems at the moment. thank you!
Tags (2)
Labels (2)
5 REPLIES 5
little edit...also when i open the file again and want to quick save houdini wants to save it as a complete new file...i don´t know whats going on there...
How do you open a file? If you are double-clicking a .hip file, this is a known issue. Use the File menu in Houdini.
// Stephen Blair
// Arnold Renderer Support
hey.
i am always using the recent files option in houdini to open files...
and again you are my hero..used the open file option and the shader is there and everything is fine...
dude big hugs and thank you man!
Ok, I'll add that info to our ticket for this issue, thanks!
// Stephen Blair
