Command Exit Code: -1073741819
william_banti75ELV
william_banti75ELV
Hello, I am trying to install Arnold for Houdini, and I am using the standard version 20.5.332… but I’m getting an error (Command Exit Code: -1073741819).
The render doesn't start in Render View or with MPlay, but if I set the output to JPG, instead of IP, it does save the image correctly...
I’m on Windows 11. I’ve tried with both the (Python 3.10) version and the standard version, but it’s the same issue...
00:00:00 67MB | [hick] Received: AA: 3 3
00:00:00 67MB | [hick] Received: begin
00:00:00 67MB | [hick] Batch mode
00:00:00 67MB | log started Tue Oct 8 13:47:19 2024
00:00:00 67MB | Arnold 7.3.4.1 [0bcd9b62] windows x86_64 clang-15.0.7 oiio-2.4.1 osl-1.13.0 vdb-11.0.0 adlsdk-8.0.7.50 clmhub-3.1.1.43 rlm-14.2.5 optix-8.0.0 2024/09/17 06:56:29
00:00:00 67MB | running on WILLIAM, pid=5564
00:00:00 67MB | 1 x Intel(R) Core(TM) i9-14900KF (32 cores, 32 logical) with 65349MB
00:00:00 67MB | NVIDIA driver version 561.09
00:00:00 67MB | GPU 0: NVIDIA GeForce RTX 4070 Ti SUPER @ 2610MHz (compute 8.9) with 16375MB (14196MB available) (NVLink:0)
00:00:00 67MB | Windows 10 (version 10.0, build 22631)
00:00:00 67MB | soft limit for open files changed from 512 to 2048
00:00:00 67MB |
00:00:00 67MB | Installing system handler with mask 255
00:00:00 108MB | [metadata] loading metadata file: C:\Users\WILLIAM\htoa\htoa-6.3.4.1_re0e79ae_houdini-20.5.332\htoa-6.3.4.1_re0e79ae_houdini-20.5.332\scripts\bin\arnold.mtd
00:00:00 112MB | loading plugins from C:\Users\WILLIAM\htoa\htoa-6.3.4.1_re0e79ae_houdini-20.5.332\htoa-6.3.4.1_re0e79ae_houdini-20.5.332\scripts\bin\..\plugins ...
00:00:00 112MB | alembic_proc.dll: alembic uses Arnold 7.3.4.1
00:00:00 112MB | [metadata] loading metadata file: C:\Users\WILLIAM\htoa\htoa-6.3.4.1_re0e79ae_houdini-20.5.332\htoa-6.3.4.1_re0e79ae_houdini-20.5.332\scripts\bin\..\plugins\alembic_proc.mtd
00:00:00 112MB | cryptomatte.dll: cryptomatte uses Arnold 7.3.4.1
00:00:00 112MB | cryptomatte.dll: cryptomatte_filter uses Arnold 7.3.4.1
00:00:00 112MB | cryptomatte.dll: cryptomatte_manifest_driver uses Arnold 7.3.4.1
00:00:00 112MB | [metadata] loading metadata file: C:\Users\WILLIAM\htoa\htoa-6.3.4.1_re0e79ae_houdini-20.5.332\htoa-6.3.4.1_re0e79ae_houdini-20.5.332\scripts\bin\..\plugins\cryptomatte.mtd
00:00:00 112MB | htoa_mandelbulb_proc.dll: mandelbulb uses Arnold 7.3.4.1
00:00:00 113MB | [metadata] loading metadata file: C:\Users\WILLIAM\htoa\htoa-6.3.4.1_re0e79ae_houdini-20.5.332\htoa-6.3.4.1_re0e79ae_houdini-20.5.332\scripts\bin\..\plugins\htoa_mandelbulb_proc.mtd
00:00:00 121MB | usd_proc.dll: usd uses Arnold 7.3.4.1
00:00:00 121MB | [metadata] loading metadata file: C:\Users\WILLIAM\htoa\htoa-6.3.4.1_re0e79ae_houdini-20.5.332\htoa-6.3.4.1_re0e79ae_houdini-20.5.332\scripts\bin\..\plugins\usd_proc.mtd
00:00:00 122MB | loaded 6 plugins from 4 lib(s) in 0:00.08
00:00:00 129MB | [hick] Start
00:00:00 128MB | [hick] Received: log_verbosity: 3590
00:00:00 128MB | [hick] Received: log_console_enable: 1
00:00:00 128MB | [hick] Received: log_file:
00:00:00 128MB | [hick] Received: log_max_warnings: 5
00:00:00 128MB | [hick] Received: delta_publisher_port: 50400
00:00:00 128MB | [hick] Received: threads: 0
00:00:00 128MB | [hick] Received: assfile: c:\users\william\appdata\local\temp\houdini_temp\htoa_WILLIAM\14172_24e0d387-b71e-4e9f-9327-2b55122c8954.ass
00:00:00 130MB | [metadata] loading metadata file: c:\users\william\appdata\local\temp\houdini_temp\htoa_WILLIAM\14172_24e0d387-b71e-4e9f-9327-2b55122c8954.ass
00:00:00 131MB | [ass] loading c:\users\william\appdata\local\temp\houdini_temp\htoa_WILLIAM\14172_24e0d387-b71e-4e9f-9327-2b55122c8954.ass ...
00:00:00 131MB | loading plugins from C:/Users/WILLIAM/htoa/htoa-6.3.4.1_re0e79ae_houdini-20.5.332/htoa-6.3.4.1_re0e79ae_houdini-20.5.332/arnold/drivers ...
00:00:00 166MB | driver_houdini.dll: driver_houdini uses Arnold 7.3.4.1
00:00:00 166MB | loaded 1 plugins from 1 lib(s) in 0:00.01
00:00:00 166MB | [ass] read 103325 bytes, 12 nodes in 0:00.01
No licenses could be found to run this application.
Please check for a valid license server host
