[BUG] 6.2.4.0 hangs in viewport and returns error on Deadline jobs
ahmed.hindy
ahmed.hindy
hi all, I have a Solaris USD scene that I have been rendering multiple layers of with HtoA 6.2.2.0 and Hou 19.5.605py3.9
I decided to give HtoA 6.2.4.0 a go on the same scene since it promised fast and cleaner mesh lights, problem is that it started to hang my Houdini session and printing errors to deadline (same local machine).
for viewport hangs, the timer keeps on counting with no word "initializing" or anything after. attempting to go back to hydra openGL or karma will simply hang Houdini, so I will have to restart Houdini after ending the process.
here is the deadline error:
2023-10-11 05:17:12:  0: DEBUG: ManagedProcess.Execute: m_process.IsRunning(): True    m_process.IsStdoutAvailable(): False
2023-10-11 05:17:12:  0: DEBUG: PopupHandler.CheckForPopups: Getting popup handles
2023-10-11 05:17:12:  0: DEBUG: PopupHandler.CheckForPopups: Got 0 handles
2023-10-11 05:17:12:  0: DEBUG: PopupHandler.CheckForPopups: Returning
2023-10-11 05:17:13:  0: DEBUG: ManagedProcess.HandleStdoutLine: parsing stdout: 00:27:28 16476MB WARNING | [driver_deepexr] HdArnoldRenderPass_driver_driver_deepexr_8: deep driver output requires all AOVs to have the same filter, will use filter "/HdArnoldRenderDelegate_00000000E7A58800/HdArnoldRenderPass_filter_9" of type "box_filter"
2023-10-11 05:17:13:  0: STDOUT: 00:27:28 16476MB WARNING | [driver_deepexr] HdArnoldRenderPass_driver_driver_deepexr_8: deep driver output requires all AOVs to have the same filter, will use filter "/HdArnoldRenderDelegate_00000000E7A58800/HdArnoldRenderPass_filter_9" of type "box_filter"
2023-10-11 05:17:13:  0: DEBUG: ManagedProcess.HandleStdoutLine: parsing stdout: 00:27:28 16476MB ERROR   | [driver_deepexr] HdArnoldRenderPass_driver_driver_deepexr_8: duplicate layer "RGBA" of type RGBA in file `G:/Projects/Challenges/pwnisher_Endless_Engines/03_Production/Shots/Seq_01/Shot_01/Renders/3dRender/render_Seq_01-Shot_01/v0031/car_sparks_env/Seq_01-Shot_01_render_Seq_01-Shot_01_v0031_car_sparks_env_deep.1131.exr'
2023-10-11 05:17:13:  0: DEBUG: ManagedProcess.HandleStdoutLine: line was matched by handler "(ERROR\s*\|.*)"
2023-10-11 05:17:13:  0: STDOUT: 00:27:28 16476MB ERROR   | [driver_deepexr] HdArnoldRenderPass_driver_driver_deepexr_8: duplicate layer "RGBA" of type RGBA in file `G:/Projects/Challenges/pwnisher_Endless_Engines/03_Production/Shots/Seq_01/Shot_01/Renders/3dRender/render_Seq_01-Shot_01/v0031/car_sparks_env/Seq_01-Shot_01_render_Seq_01-Shot_01_v0031_car_sparks_env_deep.1131.exr'
2023-10-11 05:17:13:  0: DEBUG: ManagedProcess.HandleStdoutLine: parsing stdout: [05:17:13]   1% Lap=0:27:34.43 Left=34:00:28.14 Mem=17.59 GB Peak=17.59 GB
2023-10-11 05:17:13:  0: STDOUT: [05:17:13]   1% Lap=0:27:34.43 Left=34:00:28.14 Mem=17.59 GB Peak=17.59 GB
2023-10-11 05:17:13:  0: DEBUG: ManagedProcess.Execute: process has been aborted, terminating
2023-10-11 05:17:13:  0: DEBUG: ManagedProcess.Execute: returning
2023-10-11 05:17:13:  0: Done executing plugin command of type 'Render Task'
Stephen.Blair
How do I reproduce this?
// Stephen Blair
// Arnold Renderer Support
ahmed.hindy
that error probably isnt the main cause since my viewport gets stuck without using my custom Arnold render settings LOP.
I noticed the problem happens with kitbash assets if multiple of them are in scene.
as for the driver error, I have attached a simple hipfile for my Arnold settings setup (works perfectly fine with HtoA 6.2.2.0 both inside Houdini and on Deadline local)
