Arnold menu not loading / HtoA 6.3.5.0 for Houdini 20.5.370 Linux (GCC 11.2) Python 3.11
davidjthomasvfx
Message 1 of 17
davidjthomasvfx
Houdini 20.5.370 Python 3.11.7 (main, Feb 22 2024, 17:20:49) [GCC 11.2.1 20220127 (Red Hat 11.2.1-9)] on linux
htoa-6.3.5.0_rdcc9b1c_houdini-20.5.370_gcc11
Spotted this in the htoa.json which I assume is an error...
"HTOA_PY_SUFFIX": [
{"houdini_python=='python3.10'": ".py310"}
Tried changing to 3.11 311 but the Arnold menu still does not load
Replies (16)
Message 2 of 17
Stephen.Blair
That's not an error, it's checking if you have the Python 3.10 version of Houdini.
And if you do, then you should be using the Python 3.10 version of HtoA, which by default installs in a folder with ".py310" in the folder name.
 If you have the default Houdini version (which is Python 3.11), then the default HtoA download (the one with no "py310" in the name, it should work.
I would check the details from Help > About Houdini > Show Details
// Stephen Blair
// Arnold Renderer Support
Message 3 of 17
davidjthomasvfx
Ah I see, thanks @Stephen.Blair for explaining and the support. Please see attached..
Help>About_Houdini>Show_Details.txt
for the report. Thanks!
Message 4 of 17
Stephen.Blair
Hi David
Houdini is not finding the HtoA package (htoa.json).
Loaded Packages:
    /opt/hfs20.5.370/packages/apex.json
    /opt/hfs20.5.370/packages/apex_cop.json
    /opt/hfs20.5.370/packages/kinefx.json
    /opt/hfs20.5.370/packages/ocio.json
    /opt/hfs20.5.370/packages/package_dirs.json
    /opt/hfs20.5.370/packages/sculpt.json
    /opt/sidefx_packages/SideFXLabs20.5.json
Is there an htoa.json file in /home/frankie/houdini20.5 ?
If you want to try the latest HtoA, you could download HtoA 6.3.5.0 for Houdini 20.5.370 Linux (GCC 11.2) from your Autodesk Account and run that installer.
// Stephen Blair
Message 5 of 17
davidjthomasvfx
Thanks @Stephen.Blair .
No htoa.json in /home/frankie/houdini20.5
This was a fresh install of arnold / HtoA 6.3.5.0 for Houdini 20.5.370 Linux (GCC 11.2) using the install wizard.
Working fine now, copied the..
/opt/htoa folder
htoa.json file
to
Thanks for troubleshooting.
Message 6 of 17
davidjthomasvfx
I now have licencing error. Please see InstallationLog.txt attached.
Message 7 of 17
Stephen.Blair
You need to install alien
[9015] Standard output:  Please install alien to be able to convert .rpm packages to .deb!
[9015] Standard error:  /home/frankie/Autodesk/LicensingInstaller/install.sh: line 44: alien: command not found
The Autodesk Licensing installers use rpm, but the Arnold licensing installer will conver those rpm files to deb for you. But that requires alien
// Stephen Blair
Message 8 of 17
davidjthomasvfx
Thanks for continued support. Autodesk License Manager installed and running.
Latest issue, nothing is executed when pressing the 'Sign In' button in the Autodesk License Manager. The 'Sign In' button does not link me to account login online, whereas the 'Purchase' button does link me to the Arnold purchase online.
I have an educational licence that should be picked up when I'm able to sign in using the Autodesk License Manager.
Please see licence diagnostic attached.
Message 9 of 17
davidjthomasvfx
Latest error message trying to sign in through licence manager attached.
Message 10 of 17
peterDTE7K
I spent 2 weeks on this error. License manager does not work on:
Ubuntu (all versions), Mint, Debian, PopOS, Fedora, Suse/OpenSuse (Leap and Tumbleweed), Arch based distros like Manjaro, Gentoo, etc.
Autodesk probably develops products on Rocky and License manager will only work on RHEL/Rocky/Alma. On any other distro you will get 24 API timeout error or sign in button will not open the browser. It's pity since Arnold and Houdini work perfectly well on anything. Large studios are fine since they all use network licensing.
Message 11 of 17
davidjthomasvfx
Thanks for sharing your experience with this @peterDTE7K. Does anyone know how to manually download / install the licence? I see this option in the licence manager but cannot find a download link from my account on the Autodesk website.
Message 12 of 17
davidjthomasvfx
Trying to use this portal on the Autodesk website to retrieve a RLM licence file.
https://registeronce.autodesk.com/prodreg/lookupSerialNumber.action
It's asking for a serial number.. that I don't see listed on my Arnold subscriptions page. Can anyone @Autodesk support?
Message 13 of 17
Stephen.Blair
None of that applies to Arnold. You have a single-user subscription. That requires a sign-in with an Autodesk ID. There is no license file.
And registeronce is for a different kind of Autodesk licensing, one that is no longer available.
// Stephen Blair
Message 14 of 17
davidjthomasvfx
@Stephen.Blair So you're confirming @peterDTE7K comment above that it's not possible to assign a single-user subscription licence using Licence Manager (and thus not be able to use Arnold unwatermarked) in Linux Mint?
Message 15 of 17
Stephen.Blair
No, I was commenting on the post about registeronce, serial numbers, and license files.
On any OS, if you have single-user subscription then the only way to use the license is to sign in with the Arnold License Manager.
// Stephen Blair
Message 16 of 17
davidjthomasvfx
So can you help me troubleshoot the error I posted previously?
"Thanks for continued support. Autodesk License Manager installed and running.
Please see licence diagnostic attached."
Only @peterDTE7K replied to this request.
Message 17 of 17
Stephen.Blair
Can't you contact Autodesk support? There's a dedicated installation and licensing team for this stuff.
// Stephen Blair
