Arnold keep "generating scene"
m3owfx
Message 1 of 19
m3owfx
I downloaded correct arnold version and houdini 20.0.590. It constantly showing "generating scene" but nothing show up.
I tried different versions, they all don't work. I deleted other renderers, it still didn't work
Replies (18)
Message 2 of 19
am_wilkins
Does the "Houdini Console" show any errors?
Likely erroring on something behind the scenes...
amwilkins
Message 3 of 19
m3owfx
But, I found it works in Solaris, in stage mode I don't know why... How to open Houdini console? It didn't automatically show up.
Message 4 of 19
m3owfx
I don't know why arnold only works in stage now.. in obj level, it still shows generating scene
Message 5 of 19
m3owfx
OK When I hit render, there is nothing in my houdini console, eventhough i turn on the log verbosity as "info" in "diagnostics"
Message 6 of 19
djKAB9B
Community Visitor
Community Visitor
I am having the same issue. Works in Solaris but black in Render. Nothing in Console.
Message 7 of 19
actor3d
Same issue on Mac OS - nothing in console output to suggest a problem.
Anyone from AUTODESK/ARNOLD team here ?????
@autodesk
Message 8 of 19
sebastien.blaineau.ortegaHRM3U
Hi everyone, thanks for reporting this. We haven't managed to reproduce this issue so far.
Which HtoA version are you testing ? If you can try the latest HtoA 6.3.4.0, it's possible that the error logs could give more info.
Message 9 of 19
actor3d
it is using the latest HTOA. I will generate an output to share and also will compare to pc install
Message 10 of 19
actor3d
do not have a pc to try but i wonder if its a Mac thing
Message 11 of 19
actor3d
@sebastien.blaineau.ortegaHRM3U
00:00:00 83MB | log started Thu Sep 5 13:17:04 2024
00:00:00 83MB | Arnold 7.3.4.0 [5809b986] darwin arm64 clang-17.0.6 oiio-2.4.1 osl-1.13.0 vdb-11.0.0 adlsdk-8.0.7.50 clmhub-3.1.1.43 rlm-14.2.5 2024/08/27 16:39:40
00:00:00 83MB | running on 80a997330d31, pid=11953
00:00:00 83MB | 1 x Apple M3 Pro (12 cores, 12 logical) with 36864MB
00:00:00 83MB | Mac OS 14.6.1, Darwin kernel 23.6.0
00:00:00 83MB | soft limit for open files is set at 10238
00:00:00 83MB |
00:00:00 83MB | [hick] Received: log_max_warnings: 100
00:00:00 83MB | [hick] Received: delta_publisher_port: 65371
00:00:00 83MB | [hick] Received: threads: 0
00:00:00 83MB | [hick] Received: assfile: /tmp/houdini_temp/htoa_vturchin/11314_0edb5eda-5614-4dac-9c88-5827bb3c233b.ass
00:00:00 86MB | [metadata] loading metadata file: /tmp/houdini_temp/htoa_vturchin/11314_0edb5eda-5614-4dac-9c88-5827bb3c233b.ass
00:00:00 86MB | [ass] loading /tmp/houdini_temp/htoa_vturchin/11314_0edb5eda-5614-4dac-9c88-5827bb3c233b.ass ...
00:00:00 87MB | loading plugins from /Users/vturchin/htoa/htoa-6.3.4.0_r0d5c67f_houdini-20.5.332/htoa-6.3.4.0_r0d5c67f_houdini-20.5.332/arnold/drivers ...
00:00:00 136MB | driver_houdini.dylib: driver_houdini uses Arnold 7.3.4.0
00:00:00 136MB | loaded 1 plugins from 1 lib(s) in 0:00.06
00:00:00 137MB | [ass] read 912841 bytes, 8 nodes in 0:00.06
00:00:00 137MB |
00:00:00 137MB | authorizing with license manager: user ...
00:00:03 154MB | [user] authorized user "actor3d" in 0:02.80
00:00:03 154MB | [user] expiration date: 2025-09-05T00:00:00-04:00
00:00:03 154MB |
00:00:03 154MB | [hick] renderUpdateHandler: update_type[AI_RENDER_UPDATE_BEFORE_PASS] status[AI_RENDER_STATUS_RENDERING] output_to_display[AI_DISPLAY_OUTPUT_ALL]
00:00:03 154MB | [color_manager] using color manager /out/arnold1:color_manager of type "color_manager_ocio"
00:00:03 155MB | [color_manager_ocio] /out/arnold1:color_manager : using OCIO configuration file from the OCIO environment variable /Applications/Houdini/Houdini20.5.332/Frameworks/Houdini.framework/Versions/20.5/Resources/packages/ocio/houdini-config-v2.1.0_aces-v1.3_ocio-v2.3.ocio
00:00:03 156MB | [color_manager] unable to determine rendering color space chromaticities, assuming "sRGB"
00:00:03 198MB |
00:00:03 198MB | there are 0 lights and 2 objects:
00:00:03 198MB | 1 persp_camera
00:00:03 198MB | 2 utility
00:00:03 198MB | 1 imager_denoiser_oidn
00:00:03 198MB | 2 box_filter
00:00:03 198MB | 1 gaussian_filter
00:00:03 198MB | 1 closest_filter
00:00:03 198MB | 1 polymesh
00:00:03 198MB | 2 list_aggregate
00:00:03 198MB | 3 color_manager_ocio
00:00:03 198MB | 1 driver_houdini
00:00:03 198MB |
00:00:03 198MB | rendering image at 1280 x 720, -3 AA samples
00:00:03 198MB | AA samples max <disabled>
00:00:03 198MB | AA sample clamp <disabled>
00:00:03 198MB | diffuse samples 2 / depth 1
00:00:03 198MB | specular samples 2 / depth 1
00:00:03 198MB | transmission samples 2 / depth 8
00:00:03 198MB | volume indirect <disabled by depth>
00:00:03 198MB | total depth 10
00:00:03 198MB | bssrdf samples 2
00:00:03 198MB | light <using per light samples>
00:00:03 198MB | transparency depth 10
00:00:03 198MB | full scene initialize (12 nodes)
00:00:03 199MB | creating root object list ...
00:00:03 199MB | full scene initialize done in 0:00.00 (multithreaded)
00:00:03 199MB | full scene update (13 nodes)
00:00:03 203MB | [color_manager_ocio] ai_default_color_manager_ocio : using OCIO configuration file from the OCIO environment variable /Applications/Houdini/Houdini20.5.332/Frameworks/Houdini.framework/Versions/20.5/Resources/packages/ocio/houdini-config-v2.1.0_aces-v1.3_ocio-v2.3.ocio
00:00:03 204MB | [OIDN]: gpu device 'Apple M3 Pro' created
00:00:03 208MB | [OIDN] /mat/arnold_default_imager/oidn_denoiser: using 'Apple M3 Pro' for denoising
00:00:03 208MB | scene bounds: (-1.01214898 -0.26760602 -0.972831011) -> (1.01214898 1.38463593 0.847423017)
00:00:03 208MB | full scene update done in 0:00.01 (multithreaded)
00:00:03 208MB | [light_sampler] Group 0: Total number of lights 0, sampled lights 0, fixed lights 0
00:00:03 208MB | [light_sampler] Group 0: Took 0.000000 ms to build the tree
00:00:03 208MB | [aov] parsing 2 output statements ...
00:00:03 230MB | [aov] registered driver: "/out/arnold1:iprsocket" (driver_houdini)
00:00:03 230MB | [aov] * "RGBA" of type RGBA filtered by "/out/arnold1:gaussian_filter" (gaussian_filter)
00:00:03 230MB | [aov] * "ID" of type UINT filtered by "/out/arnold1:closest_filter:aov-1" (closest_filter)
00:00:03 230MB | [aov] done preparing 6 AOVs for 4 outputs to 1 driver (0 deep AOVs)
00:00:03 234MB | [imager] Overriding the fis_filter:fis_filter_width options with gaussian:2.000000 to improve quality for denoising with imager_denoiser_oidn
00:00:03 234MB | FIS set to gaussian with width 2
00:00:03 281MB |
00:00:03 281MB | releasing resources
00:00:03 257MB |
00:00:03 257MB | releasing resources
00:00:03 256MB | Arnold shutdown
Message 12 of 19
actor3d
00:00:00 52MB | [hick] Lowered process priority to 19
00:00:00 52MB | [hick] Received: AA: -3 3
00:00:00 52MB | [hick] Received: interactive 2
00:00:00 52MB | [hick] Received: begin
00:00:00 52MB | [hick] Interactive mode
00:00:00 52MB | log started Thu Sep 5 19:29:01 2024
00:00:00 52MB | Arnold 7.3.4.0 [5809b986] darwin arm64 clang-17.0.6 oiio-2.4.1 osl-1.13.0 vdb-11.0.0 adlsdk-8.0.7.50 clmhub-3.1.1.43 rlm-14.2.5 2024/08/27 16:39:40
00:00:00 52MB | running on 80a997330d31, pid=55703
00:00:00 52MB | 1 x Apple M3 Pro (12 cores, 12 logical) with 36864MB
00:00:00 52MB | Mac OS 14.6.1, Darwin kernel 23.6.0
00:00:00 52MB | soft limit for open files is set at 10238
00:00:00 52MB |
00:00:00 52MB | Installing system handler with mask 255
00:00:00 63MB | [metadata] loading metadata file: /Users/vturchin/htoa/htoa-6.3.4.0_r0d5c67f_houdini-20.5.332/htoa-6.3.4.0_r0d5c67f_houdini-20.5.332/scripts/bin/arnold.mtd
00:00:00 64MB | loading plugins from /Users/vturchin/htoa/htoa-6.3.4.0_r0d5c67f_houdini-20.5.332/htoa-6.3.4.0_r0d5c67f_houdini-20.5.332/scripts/bin/../plugins ...
00:00:00 65MB | cryptomatte.dylib: cryptomatte uses Arnold 7.3.4.0
00:00:00 65MB | cryptomatte.dylib: cryptomatte_filter uses Arnold 7.3.4.0
00:00:00 65MB | cryptomatte.dylib: cryptomatte_manifest_driver uses Arnold 7.3.4.0
00:00:00 65MB | [metadata] loading metadata file: /Users/vturchin/htoa/htoa-6.3.4.0_r0d5c67f_houdini-20.5.332/htoa-6.3.4.0_r0d5c67f_houdini-20.5.332/scripts/bin/../plugins/cryptomatte.mtd
00:00:00 80MB | usd_proc.dylib: usd uses Arnold 7.3.4.0
00:00:00 80MB | [metadata] loading metadata file: /Users/vturchin/htoa/htoa-6.3.4.0_r0d5c67f_houdini-20.5.332/htoa-6.3.4.0_r0d5c67f_houdini-20.5.332/scripts/bin/../plugins/usd_proc.mtd
00:00:00 80MB | htoa_mandelbulb_proc.dylib: mandelbulb uses Arnold 7.3.4.0
00:00:00 80MB | [metadata] loading metadata file: /Users/vturchin/htoa/htoa-6.3.4.0_r0d5c67f_houdini-20.5.332/htoa-6.3.4.0_r0d5c67f_houdini-20.5.332/scripts/bin/../plugins/htoa_mandelbulb_proc.mtd
00:00:00 80MB | alembic_proc.dylib: alembic uses Arnold 7.3.4.0
00:00:00 81MB | [metadata] loading metadata file: /Users/vturchin/htoa/htoa-6.3.4.0_r0d5c67f_houdini-20.5.332/htoa-6.3.4.0_r0d5c67f_houdini-20.5.332/scripts/bin/../plugins/alembic_proc.mtd
00:00:00 81MB | loaded 6 plugins from 4 lib(s) in 0:00.04
00:00:00 82MB | [hick] Start
00:00:00 82MB | [hick] Received: log_verbosity: 8191
00:00:00 82MB | [hick] Received: log_console_enable: 1
00:00:00 82MB | [hick] Received: log_file:
00:00:00 82MB | [hick] Received: log_max_warnings: 5
00:00:00 82MB | [hick] Received: delta_publisher_port: 53295
00:00:00 83MB | [hick] Received: assfile: /tmp/houdini_temp/htoa_vturchin/54785_41c2e5de-47d3-43ff-8d0c-d1fffb934238.ass
00:00:00 86MB | [metadata] loading metadata file: /tmp/houdini_temp/htoa_vturchin/54785_41c2e5de-47d3-43ff-8d0c-d1fffb934238.ass
00:00:00 86MB | [ass] loading /tmp/houdini_temp/htoa_vturchin/54785_41c2e5de-47d3-43ff-8d0c-d1fffb934238.ass ...
00:00:00 86MB | loading plugins from /Users/vturchin/htoa/htoa-6.3.4.0_r0d5c67f_houdini-20.5.332/htoa-6.3.4.0_r0d5c67f_houdini-20.5.332/arnold/drivers ...
00:00:00 136MB | loaded 1 plugins from 1 lib(s) in 0:00.07
00:00:00 136MB | [ass] read 8160 bytes, 9 nodes in 0:00.07
00:00:00 136MB |
00:00:00 136MB | authorizing with license manager: user ...
00:00:03 154MB | [user] authorized user "actor3d" in 0:02.85
00:00:03 154MB |
00:00:03 155MB | [color_manager] unable to determine rendering color space chromaticities, assuming "sRGB"
00:00:03 195MB |
00:00:03 195MB | there are 1 light and 2 objects:
00:00:03 195MB | 1 persp_camera
00:00:03 195MB | 1 skydome_light
00:00:03 195MB | 2 utility
00:00:03 195MB | 1 imager_denoiser_oidn
00:00:03 195MB | 2 box_filter
00:00:03 195MB | 1 gaussian_filter
00:00:03 195MB | 1 closest_filter
00:00:03 195MB | 1 polymesh
00:00:03 195MB | 2 list_aggregate
00:00:03 195MB | 3 color_manager_ocio
00:00:03 195MB | 1 driver_houdini
00:00:03 195MB |
00:00:03 195MB | rendering image at 1280 x 720, -3 AA samples
00:00:03 195MB | AA samples max <disabled>
00:00:03 195MB | AA sample clamp <disabled>
00:00:03 195MB | diffuse samples 2 / depth 1
00:00:03 195MB | specular samples 2 / depth 1
00:00:03 195MB | transmission samples 2 / depth 8
00:00:03 195MB | volume indirect <disabled by depth>
00:00:03 195MB | total depth 10
00:00:03 195MB | bssrdf samples 2
00:00:03 195MB | light <using per light samples>
00:00:03 195MB | transparency depth 10
00:00:03 195MB | full scene initialize (13 nodes)
00:00:03 196MB | [hick] node_initialize
00:00:03 196MB | creating root object list ...
00:00:03 196MB | full scene initialize done in 0:00.00 (multithreaded)
00:00:03 196MB | full scene update (14 nodes)
00:00:03 196MB | [hick] node_update
00:00:03 196MB | /obj/arnold_skydome_light1: skydome_light using 1 sample, 2 volume samples
00:00:03 200MB | [color_manager_ocio] ai_default_color_manager_ocio : using OCIO configuration file from the OCIO environment variable /Applications/Houdini/Houdini20.5.332/Frameworks/Houdini.framework/Versions/20.5/Resources/packages/ocio/houdini-config-v2.1.0_aces-v1.3_ocio-v2.3.ocio
00:00:03 201MB | [OIDN]: Device Enum, Device 0 : Apple M3 Pro
00:00:03 201MB | [OIDN]: Device Enum, Device 1 : Apple M3 Pro
00:00:03 201MB | [OIDN]: gpu device 'Apple M3 Pro' created
00:00:03 205MB | [OIDN] /mat/arnold_default_imager/oidn_denoiser: using 'Apple M3 Pro' for denoising
00:00:03 205MB | scene bounds: (-0.5 -0.5 -0.5) -> (0.5 0.5 0.5)
00:00:03 205MB | full scene update done in 0:00.01 (multithreaded)
00:00:03 205MB | [light_sampler] Group 0: Total number of lights 1, sampled lights 0, fixed lights 1
00:00:03 205MB | [light_sampler] Group 0: Took 0.000000 ms to build the tree
00:00:03 205MB | [aov] parsing 2 output statements ...
00:00:03 228MB | [aov] registered driver: "/out/arnold1:iprsocket" (driver_houdini)
00:00:03 228MB | [aov] * "RGBA" of type RGBA filtered by "/out/arnold1:gaussian_filter" (gaussian_filter)
00:00:03 228MB | [aov] * "ID" of type UINT filtered by "/out/arnold1:closest_filter:aov-1" (closest_filter)
00:00:03 228MB | [aov] done preparing 6 AOVs for 4 outputs to 1 driver (0 deep AOVs)
00:00:03 232MB | [imager] Overriding the fis_filter:fis_filter_width options with gaussian:2.000000 to improve quality for denoising with imager_denoiser_oidn
00:00:03 232MB | FIS set to gaussian with width 2
00:00:03 276MB | [hick] driver_open: [-3 3]: -3 is_open 1
No licenses could be found to run this application.
Please check for a valid license server host
00:00:03 278MB |
00:00:03 278MB | releasing resources
00:00:03 278MB | [hick] node_finish
00:00:03 278MB |
00:00:03 278MB | unloading 5 plugins
00:00:03 278MB | closing cryptomatte.dylib ...
00:00:03 278MB | closing usd_proc.dylib ...
00:00:03 278MB | closing htoa_mandelbulb_proc.dylib ...
00:00:03 278MB | closing alembic_proc.dylib ...
00:00:03 278MB | closing driver_houdini.dylib ...
00:00:03 278MB | unloading plugins done
00:00:03 278MB | Arnold shutdown
00:00:03 278MB | Installing system handler with mask 0
Any ideas?
Message 13 of 19
Stephen.Blair
00:00:03 278MB |
Any ideas?
That's a Houdini license error message. You'll have to check your license. Google says that some people reinstall, and use hkey to check it.
https://www.sidefx.com/faq/question/render-error-no-licenses-could-be-found-to-run-this-application-...
// Stephen Blair
// Arnold Renderer Support
Message 14 of 19
actor3d
License is fine I think . Mantra renders just fine and Arnold license and Houdini licenses are on when checked.
Message 15 of 19
Stephen.Blair
This is not from Arnold or HtoA, and it certainly seems to be stopping the render.
// Stephen Blair
Message 16 of 19
peterDTE7K
I got old log from windows and new log from linux. Basically the the classic ROP has not worked for like half year for me. This is not a license issue, all licenses are set up correctly - Houdini works, Karma works, Arnold 100% works in Solaris but ROP is stuck on generating scene.
@tom_minor-arnold was able to repro the error and said: "I've done some testing on my mac and you're right, this is totally broken. I see a bunch of 'Library not loaded' errors because it can't find the Houdini libs. I've made a ticket to fix the rpaths ASAP (and figure out a way to catch this in our testsuite) - it's logged as HTOA-2706."
Message 17 of 19
actor3d
@peterDTE7K  thank you
AUTODESK/ARNOLD team let us know if its fixed please
Message 18 of 19
Stephen.Blair
That (HTOA-2706) seems to be a similar, but different issue. There were errors loading libraries, and then a driver_houdini error, and I don't see that in your logs. In your logs, hick was able to open the driver but then it just finishes.
00:00:01   291MB         | [hick] driver_open: [-3 3]: -3 is_open 1
00:00:02   285MB         |
00:00:02   285MB         | releasing resources
00:00:02   285MB         |  [hick] node_finish
I've logged HTOA-2735 for this RenderView problem that ends with node_finish. But we haven't reproduced it yet.
// Stephen Blair
Message 19 of 19
Also, HTOA-2706 was a Mac-specific issue on apple silicon. So these problems on linux & windows would be different things, even though they all end up with a render error.
Regarding HTOA-2706, Tom's point about rpaths being broken was actually a false positive due to a custom build that he was testing. When using HtoA releases he was no longer able to reproduce it (which is why there hasn't been a fix so far).
Thanks for sending us all these logs, it helps because so far we're not managing to reproduce any of these issues which makes it hard for us to fix it. We're still investigating.
