Message 1 of 1
USD Render File - Topnet render same first frame for all other frames when "All Frames in One Batch" is enabled.
When I try to render all frames in same batch only the first render is generated, all other frames are copies from this first frame. If I disable "All frames in one Batch" all frames seems to be generated correctly, but this way is very slow because all stuff need to be loaded in memory for each frame... a waste of time. Someone know a clue about this?
The same configuration with karma render propierties and karma delegate works perfectly with "All frames in One Batch" enable
