AA issue with toon shader (htoa)
alainh3d
alainh3d
I get different qualities of AA on the edges of my objects.
Is it possible to get clean edges everywhere?
Thanks a lot.
Alain
link to file: https://wetransfer.com/downloads/121b74ed87dbf6853c0815e89754372420220302121124/8ace6f22b8daacb817d0...
lee_griggs
Why contour: 4? Try increasing Camera (AA) samples. What resolution?
Lee Griggs
Arnold rendering specialist
AUTODESK
alainh3d
Hello Lee and thank you for your response.
So I put the contour filter back to default (2) and crancked up the AA samples to 12 + Max Cam AA to 20. Resolution is 2500 x 2500 pixels. But the result is the same... I still get jagged edges.
However, it might be a compositing issue... As I opened the exr in Photoshop.
I just did a test in Fusion and the result is much better. Not perfect but way better than Photoshop.
Any thoughts on this?
Alain
alainh3d
Well I think I found the bug... I comped the 2 passes (toon outline + Beauty) wrongly...
When you see the result in HTOA Renderview, it's fine. but if you want the outline + the beauty pass, you need to render them out separetly.
And the issue I have is the Alpha being post-multiplied... I think.
In Fusion if I flatten the exr (no Alpha), I get the result but if I want to comp it separetly, then the same issue happens as in Photoshop. I hope this makes sense.
Could someone please tell me how I could comp the 2 passes in a correct way? Fusion and Photoshop?
I would appreciate!
Thanks a lot.
Alain
alainh3d
Finally I found a way to comp it, both in Photoshop and Fusion...
So it was a compositing issue and not Arnold's.
Cheers.
Alain
lee_griggs
Great. How did you comp it in the end?
Lee Griggs
AUTODESK
alainh3d
Sorry Lee, I just saw your question today...
Here is the solution...
Cheers.
Alain
