Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
x-particles + Mesh Light
3 REPLIES 3
426 Views, 3 Replies
I am hoping to have my xparticles interact with a volume.
You can see below the particles are not interacting with the volume on the left.
I have tried a number of combinations of using xpCache, Alembic export, bake as alembic and connect.
Any suggestions would be highly appreciated !
Here you can see a mesh light interacting with the volume
Here is a link to the project if anyone is interested.
https://www.dropbox.com/s/nw4ar3lmjhnynvb/Alex%20Particle%20Test_0004.c4d?dl=0
Thank you !!
Tags (1)
Labels (1)
3 REPLIES 3
lee_griggs
What happens when you increase their exposure?
Lee Griggs
Arnold rendering specialist
AUTODESK
Hi Lee -- there is no response when I increase exposure
peter.horvath6V6K3
I'm guessing you are using an atmosphere_volume shader, which does not support emission. You can instance mesh lights instead of emissive spheres, or you can use an Arnold Volume in box mode instead of the atmosphere (make sure you setup volume samples and ray depth).
