Water Drop Render
Water Drop Render
nspatel62926
Water Drop Render
nspatel62926
Hello, I want to render water droplet on my object but when I render some droplet looks perfect but some are not rendering properly, can someone help me about this?
I use simple material with below attribute and with some light and arnold sky with HDRI for lighting effect.
Please suggest///
lee_griggs
Is the water drop geo penetrating the object? Is caustics enabled in the standard_surface shader?
Lee Griggs
Arnold rendering specialist
AUTODESK
nspatel62926
Hey,
Thanks for your suggations, after enable caustics in standard_surface shader it works perfectly fine.
Realy thank you for your this fast support it realy help to solve some of query and go ahead with work.
Thanks again!!!
Nayan Patel
