The only two menu items in the C4DtoA Utilities menu on a Mac are Flush Cache and Material. Is there a way to use the Bake Texture or Bake Geometry feature on a Mac? Couldn't find anything in the documentation about this being platform specific.
Solved by peter.horvath6V6K3. Go to Solution.
It's a know issue in Cinema 4D confirmed by Maxon. The workaround is using the application menu bar instead of the Mac menu bar. Go to Edit -> Preferences -> Interface and uncheck Show Mac Bar Menu.
Or more simply: just tear off the Arnold menu and dock it somewhere in the interface; then the full menu listing shows up. Save that layout to use when you are using Arnold.
