toon shader Alpha Channel
Message 1 of 10
I'm trying to do something very simple but have somehow been unsuccessful in doing so.
I need to render an object from C4DtoA that has a toon shader on transparent (no black bg) so I can use composite things over and underneath it.
Somehow every time I try to do this, I'm only able to render the outline, and not the whole objects alpha. I downloaded the Arnold toon shader demo file and rendered that (its set up to render multi-pass out of C4D) and even that file only gives me the outline, not the full alpha.
Very difficult becaues I can't composite anything, any help would be hugely appreciated!
Replies (9)
Message 2 of 10
peter.horvath6V6K3
Unfortunately there's a technical limitation to dispaly the full alpha at the moment. What you can do is to create a custom AOV for the edges, as described here:
https://support.solidangle.com/pages/viewpage.action?pageId=71008418
We're trying to simplify this in a future release.
Message 3 of 10
@Peter Horvath Is there a chance than you can explain better how do that, the documentation says the minimum and is very difficult to understand for a beginner (i read the whole AOV and Toon documentation and i still can't get what OP Saad is asking).
I only get multiple AOV with Toon lines, no shaders.
Also i dont get how you can have a Contour filter for and AOV and a Box filter for another on the same file and same render.
maybe a little step by step would be really great in your documentation.
Thank you.
Message 4 of 10
Stephen.Blair
@Ste Pha Please post a new question. Please don't post your new question as an answer to another question.
// Stephen Blair
// Arnold Renderer Support
Message 5 of 10
peter.horvath6V6K3
Check out this scene: toon-separate-edges.zip
The default filter in the render settings is set to box_filter. The custom AOV, called 'edges', uses a custom contour_filter.
I also added this scene to the docs.
Message 6 of 10
crowellster
Observer
Observer
Any chance this has been updated? It's so frustrating and confusing to use. I want to use the contour filter in my IPR window and have that not affect my exports. I'm struggling to get the alpha channel to work properly, as well.
Message 7 of 10
peter.horvath6V6K3
Sorry, no updates on this, the preferred workflow is still creating a custom AOV with the contour filter.
Message 8 of 10
The example toon file supplied is broken (causes render failure due to issue with window-border file) - I'm in C4d R21
All I can get to render using that custom AOV technique is white edges without any diffuse layer. Perhaps I'm missing a step but it's frustrating that something something as simple as rendering alpha requires a wacky workaround.
Clearly support for this render engine is lacking if plans were made 3 years ago to simplify this process and still today it's the same old same old...
Message 9 of 10
Kidmograph
Hi @peter.horvath6V6K3, @Stephen.Blair, wondering if there's an update on this workflow. I have a project with dozens of scenes and having this fixed would be great to speed up things. Thank you.
Message 10 of 10
peter_horvath
Sorry, it's still the same workflow.
// Peter Horvath
// C4DtoA developer
