Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
This is realistic cloud render by Frederic. The inside is much more bright than outside. He said that just increase volume depth = 50 with a physical sky. But I even increase it = 999. The result is still not good. Why ?Thank you so much !
7 REPLIES 7
Message 1 of 8
David_Kuperper
553 Views, 7 Replies
7 REPLIES 7
Message 2 of 8
Slava_91
in reply to: David_Kuperper
Hi! He use PhisicalSky for light, you need setup ray depth to 50+ set Total depth to 100 and volume to 50 in render settings.
But get ready, you render can work very slowly
Message 3 of 8
at the begginning I uploaded the image about setting above, now I re-upload. I set it volume depth = 999, total depth = 999, Physical sky Max bounce = 999. It's still not working good result.
Message 4 of 8
David_Kuperper
in reply to: Slava_91
Message 5 of 8
Why no one can help me ?! 😞
Message 6 of 8
lee_griggs
I see from your post on Twitter that you were able to resolve this.
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 7 of 8
We all must be missing something here. On facebook youve stated you rendered this on a laptop, but with 999 volume bounces this should take an eternity... like easily several days. If you are getting results in anything remotely reasonable, then youre just not getting 999 bounces. unfortunately, im just not sure what could be going on, either. Maybe something to do with the adaptive sampler?
Message 8 of 8
We will publish a tutorial soon.
