Shader color from camera distance
pacox21
pacox21
Hello 🙂
Is there a way to input the camera distance into a shader to control its color ?
I can't find any solution ...
Thanks for your help !
Francis
peter.horvath6V6K3
You can access the ray length (Rl) via a state_float shader, which is the distance from the ray origin (camera) to the shading point.
pacox21
Thanks Peter, I'll give it a try and share my progress !
pacox21
I can't get it to work ... I don't get how to output a Z like render of my surface with a black and white gradient ... Any tip ?
pacox21
I plug the output of the RL into a ramp_float node, but all I can get is a uniform color, even when I play with the spline or the UV projection
peter.horvath6V6K3
It's an absolute distance (in meters), you need to remap with a range shader.
pacox21
It works !! Thank you for your help Peter ! capture-decran-2021-02-18-a-152311.png
