Restrict Thin Film
Restrict Thin Film
lizGYM66
Restrict Thin Film
lizGYM66
How do I restrict the effect of thin film to a particular area, rather than everywhere? I.e. in this case just to the bottom of the pan?
lee_griggs
You could use a ramp -> mix_shader.mix_weight or layer shader with the pan shader in one slot and the pan shader with thin film in the other.
Lee Griggs
Arnold rendering specialist
AUTODESK
peter.fagerberg
Or, if I understand you correctly and the geometry is up for it, you could maybe use a vertex map to identify the area where you want the "coated" look. Vertex maps are often super useful when you want to apply different shaders to different areas of a geometry.
lizGYM66
That's what I thought of after I posted 🙂
