pyro render issue [GPU and CPU]
honorsforgod
honorsforgod
hi
it's been a while
I am using the latest version of cinema and Arnold and Nvidia drive (RTX 3080ti) and I have this issue
GPU is not Working but Cpu is okay in IPR but sometimes does not work In the image viewer
screenshots here
https://1drv.ms/u/s!AvvDKN0qWC-PlEaxXJytPqQvv9Lh?e=FZYwwC
peter_horvath
Rendering Pyro directly on the GPU is not working at the moment, it's a limitation. You can cache the simulation and load the VDB volume with the Arnold Volume object. That can be rendered on the GPU.
To be able to render in the IPR, you have to set the channels in the Pyro object to On, as discussed in this thread: https://forums.autodesk.com/t5/arnold-for-cinema-4d-forum/new-pyro-tag-in-c4d-arnold-how-to-actually...
// Peter Horvath
// C4DtoA developer
