Multi texture shader to cloner objects
Message 1 of 37
Hello. Is it possible to aplly a multi texture shader, in a linear order (1st, 2nd, 3rd, ...) to the objects of a linear cloner, just as the mograph shader does? Let's say, like pages in a magazine, one shader for multiple pages with the textures in the right pages in sequence, not randomly. I'm trying to do it with the Switch Shader nome but getting stuck in the index parameter. I've tryed the Range none attached to the index value of the Switch Shader, but no success.
Any help would be appreciated, thank you.
Replies (36)
Message 2 of 37
Eden_Soto1
I'd like to know the answer to this as well... I ran into a similar issue the other day and couldn't find a way.. wound up creating 20+ individual materials for a stack of vinyl record covers in a cloner... was super tedious
Message 3 of 37
https://www.youtube.com/watch?v=Eh7FG3r9rFA - Watch this you'll get all the info you need.
Message 4 of 37
No good for me. That example is for randomization. What I need is to make it linear.
What I'm working on is a linear cloner, and the textures must be apllied in the correct order.
1st texture applied to the 1st clone, 2nd to the 2nd, 3rd to the 3rd, and so on. So, I need a way to linearize the index of the "switch shader". I believe there was a "linearize" node (which was driven by object ID) in the first versions of arnold, but it's not there anymore, and I can't figure out which node replaces it.
Anyway, thank you. Every knowledge is good knowlege.
Message 5 of 37
Hi
One Arnold Shader with multi textures (Maya):
Use Tokens <attr:> or <shapename>
video here: https://www.youtube.com/watch?v=OtL7HMWyBPI
Message 6 of 37
peter.horvath6V6K3
Currently you can access only the display color of the clones from the shader network. So you can use a gradient based on the index and than drive a switch shader with the display_color user data. Also note that the color in Arnold is linearized, so you need to apply a 2.2. gamma. See the attached scene: cloner-multi-texture.zip
What we're missing currently is accessing the index of the clones, which makes this a lot easier. I'll add it in a future release.
Message 7 of 37
Thanks @Peter Horvath. It was a great help. I took a dive into your file and a light shone inside my head. I went ahead and made some changes, I don't know yet if it solves my problem but I've found a way to distribute the colors on to the objects in the correct order... well... actualy is the reverse order, but is a start. I've changed the shader effector for a step effector and in attributes>parameter>color mode I've selected "effector color" (because the step effector applies different shades to the cloner objects in the display window, and the "user_data_rgb" node was huge discovery for me) then selected "use alpha/strenght" and "subtract" for the blending mode. And voilá... the colors are distributed in the correct order, but from end to start, like the last clone has the zero index (can't figure out this part). Anyway, I'm attatching the file. And I'll later try with textures rather than just colors, which is what I'm aiming for.
Again thank you so much for your help.
Message 8 of 37
@Peter HorvathI've figured out how to distribute the colors in the right order from start to end. One just need to adjust/invert the spline of the the effector, as shown in the picture. And I've tested with images and it works. Perfect!!! Thanks again for your help.
Message 9 of 37
peter.horvath6V6K3
Great, I'm glad it's working, hopefully the workflow will be easier soon.
Message 10 of 37
i forgot there was a tutorial( https://vimeo.com/139620806 ) on this..(arnold 4)
Message 11 of 37
Mike_Ligocki
This is fine for random color but you can't control the iteration of the shaders in this execution. It's not a replacement for the Multi-shader and doesn't get you anywhere close.
Message 12 of 37
True........
Message 13 of 37
I'll post a tutorial soon, based on my findings.
I've already fine tuned the shader since my previous post.
I'm testing it on different projects and so far it's working, At this point I'm able to distibute the textures in a linear order, from 1st to Nth, in any kind of cloner object. But, I don't know yet the limit number of clones that allows this to work properly. So far the maximum I've tested was ten clones, anyways the "switch_rgba" node only supports 20 different inputs, so maybe that will be the limit.
Message 14 of 37
when you post the tutorial, link it up here.
Message 15 of 37
peter.horvath6V6K3
The new version, C4DtoA 2.5.1 exports the index of the clones as a user data. So now you should be able to use a user_data_int shader with the attribute index, to do an easy linear shading over the clones.
Message 16 of 37
Thanx @Peter Horvath that's great and it works perfectly! 🙂
Message 17 of 37
Please show an example..I've forgotten the way.
Message 18 of 37
peter.horvath6V6K3
Here's a simple example with a switch shader and the user_data_int reading the index of the clones.
Message 19 of 37
Thanks..I'd already figured it out some days ago..still thanks
Message 20 of 37
Hello, somehow in C4D R21 and Arnold 6, this isn't working... what has happened?
