License Manager Crashes
mckenzie2VER2
Message 1 of 8
mckenzie2VER2
When I try to sign in to Arnold License manager, LM crashes after clicking the 'Sign In' button.
I've un-installed C4DA and re-installed with no luck.
Below is the log from ALM:
2022-06-27 10:34:16 INFO | Arnold license manager started
2022-06-27 10:34:16 DEBUG | CLM v1 API v2.0.0.235
2022-06-27 10:34:16 DEBUG | CLM v2 API v6.3.1.44
2022-06-27 10:34:16 DEBUG | show main window
2022-06-27 10:34:16 INFO | request licensing model info
2022-06-27 10:34:16 INFO | license order from Arnold config
2022-06-27 10:34:16 DEBUG | load Arnold config: /Users/shanemckenzie/Library/Preferences/Autodesk/Arnold/config
2022-06-27 10:34:16 INFO | license_order: user
2022-06-27 10:34:16 INFO | licensing model info received: user
2022-06-27 10:34:16 INFO | request single user licensing info
2022-06-27 10:34:16 DEBUG | run: /Applications/Maxon Cinema 4D R26/arnold/bin/kick --version
2022-06-27 10:34:17 INFO | Arnold version: 7.1.2.0
2022-06-27 10:34:17 INFO | Arnold build date: 20220519
2022-06-27 10:34:17 INFO | Arnold product key: C0PO1
2022-06-27 10:34:17 INFO | Arnold product version: 2023.0.0.F
2022-06-27 10:34:17 INFO | Arnold network feature name: 87752ARNOL_2023_0F
2022-06-27 10:34:17 DEBUG | Single-user installer: /Applications/Maxon Cinema 4D R26/arnold/license/installer/Autodesk_Licensing-12.0.0.6529_02.dmg (12.0.0.6529_02)
2022-06-27 10:34:17 DEBUG | NLM installer: /Applications/Maxon Cinema 4D R26/arnold/license/installer/Autodesk_NLM-11.18.0.0_01.dmg (11.18.0.0_01)
2022-06-27 10:34:17 DEBUG | AdskLicensingSupportTool: /Applications/Maxon Cinema 4D R26/arnold/license/installer/AdskLicensingSupportTool-2.1.0.446-mac.zip (2.1.0.446)
2022-06-27 10:34:17 DEBUG | [adlsdk] create session
2022-06-27 10:34:17 DEBUG | [adlsdk] create session done (0x600002a0c670)
2022-06-27 10:34:17 DEBUG | [adlsdk] initialize sign in status
2022-06-27 10:34:20 DEBUG | [adlsdk] UiUpdateCallback called
2022-06-27 10:34:20 DEBUG | [adlsdk] UiUpdateCallback -- item ACTION_SIGN_IN (1)
2022-06-27 10:34:20 DEBUG | [adlsdk] initialize sign in status done
2022-06-27 10:34:20 INFO | [clmv2] check product registration (key: C0PO1, version: 2023.0.0.F)
2022-06-27 10:34:20 DEBUG | [clmv2] run: "/Library/Application Support/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper" list
2022-06-27 10:34:20 INFO | [clmv2] product is registered
2022-06-27 10:34:20 INFO | single user licensing info received:
installed: yes
version: 12.0.0.6529
outdated: no
update available: no
product registered: yes
signed in: no
2022-06-27 10:34:20 INFO | request single user license info
2022-06-27 10:34:20 INFO | single user license info received:
licensing available: no
2022-06-27 10:34:22 DEBUG | [adlsdk] send sign in action
2022-06-27 10:34:22 DEBUG | [adlsdk] wait for sign in
2022-06-27 10:34:22 DEBUG | [adlsdk] UiEnterModalCallback called
2022-06-27 10:35:50 DEBUG | [adlsdk] UiExitModalCallback called
2022-06-27 10:35:50 DEBUG | [adlsdk] sign in done
 OS X 12.3.1
 C4D S26.015
 C4DA 4.2.3
 ALM 1.3.1
Any suggestions?
Replies (7)
Message 2 of 8
mckenzie2VER2
From License Diagnostics:
License diagnostics executed at 2022-06-27 10:48:01
Autodesk Desktop Licensing Version: 12.0.0.6529
Installing AdskLicensingUpdateTool to /Users/shanemckenzie/Library/Application Support/Autodesk/Arnold
unzip /Applications/Maxon Cinema 4D R26/arnold/license/installer/AdskLicensingSupportTool-2.1.0.446-mac.zip -d /Users/shanemckenzie/Library/Application Support/Autodesk/Arnold
kick -nostdin -v 1 -i /dev/null (1.64 sec)
00:00:00 57MB | log started Mon Jun 27 10:48:01 2022
00:00:00 57MB | Arnold 7.1.2.0 [a68d7fc3] darwin clang-10.0.1 oiio-2.4.0 osl-1.12.0 vdb-7.1.1 adlsdk-6.3.1.44 clmhub-2.0.0.235 rlm-14.1.3 2022/05/19 13:04:33
00:00:00 57MB | running on Shanes-Mac-Pro.local, pid=15415
00:00:00 57MB | 1 x Intel(R) Xeon(R) W-3245 CPU @ 3.20GHz (16 cores, 32 logical) with 98304MB
00:00:00 57MB | macOS 10.16.0, Darwin kernel 21.4.0
00:00:00 57MB | soft limit for open files is set at 10238
00:00:00 57MB |
00:00:00 74MB | [color_manager_ocio] default ocio.config found in /Applications/Maxon Cinema 4D R26/arnold/bin/../ocio/configs/arnold/config.ocio
00:00:00 74MB | loading plugins from /Applications/Maxon Cinema 4D R26/arnold/bin/../plugins ...
00:00:00 74MB | loaded 5 plugins from 3 lib(s) in 0:00.01
00:00:00 74MB | [kick] command: /Applications/Maxon Cinema 4D R26/arnold/bin/kick -nostdin -v 1 -i /dev/null
00:00:00 74MB | loading plugins from . ...
00:00:00 74MB | no plugins loaded
00:00:00 78MB | [ass] loading /dev/null ...
00:00:00 78MB | [ass] read 0 bytes, 0 nodes in 0:00.00
00:00:00 78MB |
00:00:00 78MB | authorizing with license manager: user ...
00:00:01 91MB WARNING | rendering with watermarks because of failed authorization:
00:00:01 91MB | [clm.v2] SERVICE (7): login requires GUI mode
00:00:01 91MB | environment variables:
00:00:01 91MB | ARNOLD_LICENSE_ORDER = (not set)
00:00:01 91MB | ARNOLD_LICENSE_MANAGER = (not set)
00:00:01 91MB | [rlm] solidangle_LICENSE = (not set)
00:00:01 91MB | [rlm] RLM_LICENSE = (not set)
00:00:01 91MB | [clm] ADSKFLEX_LICENSE_FILE = (not set)
00:00:01 91MB | [clm] LM_LICENSE_FILE = (not set)
00:00:01 91MB |
00:00:01 91MB |
00:00:01 91MB | releasing resources
00:00:01 91MB |
00:00:01 91MB | Arnold shutdown
kick -licensecheck (0.10 sec)
RLM DEBUG for product "arnold"
0 product instances found
Could not find any license files, please check the license server, the license may be expired
Please contact [email protected]
environment:
solidangle_LICENSE = (null)
RLM_LICENSE = (null)
AdskLicensingSupportTool --version (0.65 sec)
AdskLicensingSupportTool Version: 2.1.0.446.
AdskLicensingSupportTool --info (0.33 sec)
---VERSION INFORMATION---
Service status: Running
AdskLicensingService version: 11.2.3.2987
Installer version: 12.0.0.6529
AdskLicensingAgent version: 5.12.1.2153
AdskLicensingInstHelper version: 2.11.0.666
AdskLicensingSupportTool version: 2.1.0.446
---LICENSING V2 PRODUCTS INFORMATION---
There are 3 Licensing v2 Autodesk products registered on this PC.
PRODUCT 1
feature_id: ARNOL
def_prod_key: C0PN1
def_prod_ver: 2022.0.0.F
sel_prod_key: C0PN1
sel_prod_ver: 2022.0.0.F
authorize_succ: True
supported_lic_methods: Network, Standalone, User
serial_number_sa: xxx-xxxxxxxx
serial_number_nw: xxx-xxxxxxxx
icon: /uiassets/1f671890837ccfded41f4e4c00f5451e.png
background: /uiassets/640d6886f3593fa572049bd0d2a702f5.png
highlight: {'red': {'value': 157}, 'green': {'value': 198}, 'blue': {'value': 204}, 'alpha': {'value': 1}}
sel_lic_method: User
PRODUCT 2
feature_id: ARNOL
def_prod_key: C0PO1
def_prod_ver: 2023.0.0.F
sel_prod_key: C0PO1
sel_prod_ver: 2023.0.0.F
icon: /uiassets/c4f6b5cecde5b62d070d48a59fd2c59b.png
background: /uiassets/c604a30d986b3be0ead7de7f6c9c78a9.png
PRODUCT 3
feature_id: MAYA
def_prod_key: 657O1
sel_prod_key: 657O1
user_lic_enabled: True
trial_enabled: True
cls_check_succ: True
icon: /uiassets/caa7e45afa57d77aff9601c221539a87.png
background: /uiassets/c192fce10832d507e9faac27d8775d45.png
highlight: {'red': {}, 'green': {}, 'blue': {}, 'alpha': {}}
AdskLicensingSupportTool --getlogs /Users/shanemckenzie/Library/Application Support/Autodesk/Arnold/AdskLicensingLogs (0.56 sec)
Successfully collected Licensing files.
Successfully collected Sdk files.
No Webservice log files found in:
/Library/Application Support/Autodesk/Web Services/Log/WebServices.log
No Loginstate log files found in:
/Library/Application Support/Autodesk/Web Services/LoginState.xml
Successfully collected Install files.
No Adlm log files found in:
/Library/Application Support/Autodesk/AdskLicensingService/Log/adlm-err*.log
WARNING: The following collected logs are NOT verbose
AdskLicensingService.2022-06-26.001.log, AdskLicensingService.log, AdskLicensingService.2022-06-27.001.log, AdskLicensingService.2022-06-25.001.log, AdskLicensingAgent_2022-06-25_11-46-33-884_882ba9cc-9691-4f8c-46a7-e7cfd3bbe4df.log, AdskLicensingAgent_2022-06-27_10-27-53-489_fc188d9f-09c6-4412-79a2-9138966b10dd.log, AdskLicensingAgent_2022-06-26_17-04-19-929_ba86c326-15d7-4b35-51ff-95d1705b6ade.log, AdskLicensingAgent.log, AdskLicensingAgent_2022-06-27_10-34-18-103_512529ad-2050-45da-575e-262f47920453.log, AdskLicensingAgent_2022-06-27_10-47-36-877_6a6bf199-1229-47eb-5db0-79eafb361f77.log, AdskLicensingAgent_2022-06-26_12-40-14-498_5bc05bb8-1199-4bab-6ac7-be8c3afa542a.log, AdskLicensingAgent_2022-06-27_10-48-02-069_8f82a0c0-1ae8-4c2f-6bca-9f66df32a90a.log, AdskLicensingAgent_2022-06-26_17-05-29-325_30be9764-dad5-409a-6c6a-c73eeebca753.log, AdskLicensingAgent_2022-06-25_11-46-33-565_40b49125-e136-4543-615e-9ffdd73f5e2a.log, AdskLicensingAgent_2022-06-27_10-48-02-094_6356d2ed-5293-47a5-6276-c52f41ac0f6e.log, AdskLicensingAgent_2022-06-27_10-27-53-471_53b8ac9f-8250-4e98-7da5-db98d675a5b0.log, AdskLicensingAgent_2022-06-25_11-46-44-924_00fbf3b3-126c-4878-7e40-10030be5f47d.log, AdlSdk-ArnoldLicenseManager-11375.log, AdlSdk-15364.log, AdlSdk-15415.log, AdlSdk-ArnoldLicenseManager-15364.log, AdlSdk-11375.log, AdlSdk-14190.log, AdlSdk-14822.log, AdlSdk-ArnoldLicenseManager-11123.log, AdlSdk-10258.log, AdlSdk-Arnold-14190.log, AdlSdk-ArnoldLicenseManager-14249.log, AdlSdk-14249.log, AdlSdk-Arnold-15415.log, AdlSdk-ArnoldLicenseManager-10258.log, AdlSdk-11123.log, AdlSdk-ArnoldLicenseManager-14822.log.
Run the -svl command to set verbose logging.
WARNING: Verbose logging found enabled in
AdskLicensingAgent_2022-06-27_10-26-50-362_48ffa98d-df2f-4b53-7681-2718a3b27035.log.
Run the -sdl command to reset to the default logging level to reduce unnecessary disk space usage.
Log files and info collected to: /Users/shanemckenzie/Library/Application Support/Autodesk/Arnold/AdskLicensingLogs/info-and-logs.zip
lmutil lmstat -S adskflex -a -f 87752ARNOL_2023_0F (0.38 sec)
lmutil - Copyright (c) 1989-2018 Flexera. All Rights Reserved.
Flexible License Manager status on Mon 6/27/2022 10:48
Error getting status: Cannot find license file. (-1,359:2 "No such file or directory")
rlmutil rlmhostid -q ether (0.15 sec)
e450ebb80b54 e450ebbd0489 88665a37db84 029481a9dc0d 029481a9dc00
FlexLM environment (0.00 sec)
ADSKFLEX_LICENSE_FILE (local env) =
ADSKFLEX_LICENSE_FILE (global user env) =
Adlm FlexNET cache =
Adlm FlexNET cache location = /Users/shanemckenzie/.flexlmrc
Message 3 of 8
mckenzie2VER2
So I updated to Monterey 12.4 and that fixed it. Weird.
Message 4 of 8
peter_horvath
Glad to hear, that the update fixed it. It's weird indeed, haven't seen any issues specific to 12.3.1 before, but will keep an eye on it.
// Peter Horvath
// C4DtoA developer
Message 5 of 8
mckenzie2VER2
Ok, so updated to the latest release of Arnold and have the same problem again. As soon as I login into the license manager it crashes.
Message 6 of 8
mckenzie2VER2
I found the uninstall script for license manager and ran it. Reinstalled Arnold and it worked after a reboot.
Is this going to be necessary with future updates? Never used to be an issue.
Message 7 of 8
peter_horvath
Definitely should not be necessary. The latest release was not even updating the licensing components. It's hard to tell what's going on. From your original post it seems that the sign-in component was crashing. If it happens again and the crash report dialog pops up, please send in the report with a comment and let me know, so we can identify it and look at the details.
// Peter Horvath
// C4DtoA developer
Message 8 of 8
mckenzie2VER2
just a heads up that this is still an issue.
after a clean OS install and installing Arnold, the LM crashed straight away. Reinstalling the LM from the included package in the Arnold folder resolved it. Seems like it doesn't install properly first time around.
This is the version that is included.
