I can't use gpu.
I can't use gpu.
I can't use gpu.
c4dto cannot detect my gpu(rtx2070s)
in console
[c4dtoa] 00:00:00 3169MB WARNING | [gpu] no compatible GPU found for GPU-rendering: Unable to load Optix library, NVIDIA driver 466.63 is either too old or missing the Optix library
[c4dtoa] 00:00:00 3170MB ERROR | [gpu] Unable to load Optix library, NVIDIA driver 466.63 is either too old or missing the Optix library (GPU-rendering)
[c4dtoa] 00:00:00 3184MB WARNING | Aborted by user: received abort signal
lee_griggs
Have you updated to the latest NVIDIA graphics drivers?
https://docs.arnoldrenderer.com/display/A5AFCUG/Getting+Started+with+Arnold+GPU
Lee Griggs
Arnold rendering specialist
AUTODESK
I have updated to the latest version
Can you tell me how to delete C4Dto completely? Because after I reinstalled c4dto, the settings are the same as before.
Stephen.Blair
It's not C4DtoA that's the problem, it's the driver install.
Unless you also have an older version of C4DtoA, which you can remove using Windows Control Panel.
Also, see this related question:
https://answers.arnoldrenderer.com/questions/31061/optix-denoisers-missing-after-update-3dsmax.html
// Stephen Blair
// Arnold Renderer Support
