Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
moving screen texture
3 REPLIES 3
gomeslindsay
144 Views, 3 Replies
hello im looking to achieve a moving screen effect and want to know how to achieve something like the picture I provided the method I though out was having a glass texture and below it the same shape object with an emission that projects a bitmap shader playing an image sequence with whatever I want behind it. is this the right method or is there another also if the method I provided is right how to I perfectly uv the image sequence around the object
Tags (1)
Labels (1)
3 REPLIES 3
lee_griggs
in reply to: gomeslindsay
Have you tried the uv_projection or uv_transform shaders?
Lee Griggs
Arnold rendering specialist
AUTODESK
gomeslindsay
in reply to: lee_griggs
nope will try that also is the method I mentioned right for my screen or is there another method ?
lee_griggs
I don't see why not. Did you try it?
Lee Griggs
AUTODESK
