Hello there!
I am new to Arnold and just C4D in general. Can someone please explain to me how to make this colored glass effect using Arnold? I was able to achieve an iridescent look by changing the thin film and transmission setting which was close. However, I couldn't figure out how to get this orange gradient from the bottom to clear glass at the top. I attached a reference for what I am trying to achieve. Thank you!
Solved by pixelpeepH7GXH. Go to Solution.
Hello Emily.
Perhaps try putting a 'ramp_RGB' plugged into the Transmission Colour. Set the ramp to be in "v" if you want a vertical gradient like the image above and play with the gradient settings for colour and location of the gradient knots.
