hello guys i have an alembic file that contains 250 frames , the object are only shown in arnold in 1-90 frames then it disappears !
screenshot-1.pnghello guys i have an alembic file that contains 250 frames , the object are only shown in arnold in 1-90 frames then it disappears !
Stephen.Blair
Post a detailed Arnold log for a frame.
// Stephen Blair
// Arnold Renderer Support
screenshot-2.png is this what you want ?
Stephen.Blair
The geometry is invalid:
WARNING| resetting parameter vlist on X (found: nans or infs)
vlist is the list of vertices. Some vertex coordinates are not a number or infinite values, so Arnold resets the list of vertices, and then there are no vertices.
// Stephen Blair
peter.horvath6V6K3
Here's a similar issue: https://answers.arnoldrenderer.com/questions/18550/degenerate-polygon-objects-found-in-frame-x-error...
The user had to add a clean node in Houdini to delete the invalid values and reexport the alembic file.
