Displacement edge
Displacement edge
yuki41_yuki41
Displacement edge
yuki41_yuki41
I have some displacement artifacts on the edge (on the top) of my object. See attached file.
What caused this to happen?
I have activated autobump to smooth out the "artifacts" but that doesn't work.
I use a subdivision of 2 iterations and the type is catclark.
lee_griggs
What happens with more iterations? What do the wireframe and normals look like?
Lee Griggs
Arnold rendering specialist
AUTODESK
yuki41_yuki41
Hi Lee,
Thanks for responding. More iterations don't seem to work. And i guess the normals are fine 🙂 I think the problem occurs when i use sculpting? I have included the scene file, maybe this will be more of help.
I couldn't upload the HD version of the displacement map because it's around 30mb. I have included a "downgraded" version
displace.zip
part-artifact.zip
lee_griggs
This is what I get with 3 subdivisions. 8 iterations killed my machine (do you really need that many?).
Lee Griggs
AUTODESK
yuki41_yuki41
i guess the 8 iterations was still there when i tried to use an "extreme" value. Is this with the sculpting activated? Because then the artifact occurs.
lee_griggs
I just reduced the iterations and rendered.
Lee Griggs
AUTODESK
yuki41_yuki41
Thanks for helping out!
