Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
color convert rgb to hsv
1 REPLY 1
114 Views, 1 Reply
2503902676
Why do I get this result after using this node?
1 REPLY 1
peter_horvath
in reply to: 2503902676
peter_horvath
If you convert (1, 0, 0) from RGB to HSV space, the result is (0, 1, 1). The output of the shader graph is expected in RGB space, so if you display the HSV output, you'll see (0, 1, 1) cyan. Normally if you need to operate in HSV space, first you convert the input to HSV, do your stuff and convert it back to RGB.
// Peter Horvath
// C4DtoA developer
// Peter Horvath
// C4DtoA developer
