Camera DOF Firefly and Artifacts
mphillips0007
mphillips0007
I have a render with Camera DOF enabled.  The issue I am having is with fireflies or artifacts in the render and not sure what is causing the issue.  I am lighting my scene with a skydome_light with samples set to 3 and point_light with samples also set to 3.  I read that Camera AA effects motion blur and DOF quality?  I have turned Camera AA up to 10 and still have artifacts.  Its mostly in the highlights and can easily be repaired in Photoshop but I really would like the renders as clean as possible to limit post production.  I have attached images of my render settings and pictures of artifacts.  Any advice would be greatly appreciated.
Replies (9)
lee_griggs
You could try increasing Camera (AA) samples or using Adaptive Samling. You could try adjusting the standard_surface.specular_roughness too. There is also Clamping and denoising.
Lee Griggs
Arnold rendering specialist
AUTODESK
mphillips0007
Ok, will try that.
lee_griggs
I have been getting very clean results with only 8 Camera (AA) samples using the OIDN denoiser imager here with scenes that have heavy DOF.
Lee Griggs
AUTODESK
mphillips0007
Thanks, your renders look really good.
mphillips0007
@lee_griggs Do you know of any good tutorials showing how to use OIDN denoiser?  Im guessing doing this will improve render times versus turning up Camera AA?
lee_griggs
mphillips0007
@lee_griggs
Thanks so much for your help.
mphillips0007
@lee_griggs
Lee just wanted to say thank you again for sharing.  Using this noise reduction is amazing and such a time saver.
lee_griggs
Glad to hear it!
Lee Griggs
AUTODESK
Type a product name
