C4DtoA 4.8.5 and 4.8.5.1 have different documented system requirements
thinkbox-licensing-external
When reviewing the release notes for C4DtoA 4.8.5 and 4.8.5.1, I noticed that the two versions have different systems requirements, with 4.8.5 having more strict requirements than 4.8.5.1 even though 4.8.5.1 is newer.
The 4.8.5 docs indicate that Linux with at least glibc 2.28 is required, while the 4.8.5.1 docs indicate that Linux with at least glibc 2.17 is required.
The underlying Arnold 7.4.4.1 release notes for C4DtoA 4.8.5.1 also include a system requirement of Linux with at least glibc 2.28, so it seems like this might be a typo.
Does the documentation need to be updated?
Joel Wong, Software Engineer @ AWS Deadline Cloud
peter_horvath
It was a documentation error and fixed now. glibc 2.28 is the requirement since C4DtoA 4.8.5 / Arnold 7.4.4.0. Thank you for reporting.
// Peter Horvath
// C4DtoA developer
Thank you! One more slight difference, are 4.8.5.1 and 4.8.5.2 compatible with macOS 10.13 or only macOS 11? The underlying Arnold version is only compatible with macOS 11, so I imagine that's a typo as well?
peter_horvath
Yes, thank you, the macOS version is also a typo. 11 is the correct one, we're going to fix this soon.
// Peter Horvath
// C4DtoA developer
Thanks, appreciate it!
