Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Bug with Toon Render/Clip_Geo
4 REPLIES 4
516 Views, 4 Replies
I noticed that when using a clip_geo object in combination with a toon shader the clipped area in fills in with black. I had others on different machines verify and was advised to share here. Using 3.2.0 on r23 and/or r21. Thanks!
When moving the object:
When releasing the object and letting Arnold resolve the scene:2.jpg
Tags (1)
Labels (1)
  • bug
4 REPLIES 4
lee_griggs
Have you tried disabling receive shadows for the clipping sphere?
Lee Griggs
Arnold rendering specialist
AUTODESK
Yup I have both of the receive/self shadows disabled. I had not opened this for a few days, just opened and now it is working perfectly??? I'll take it.
MarcelRuchArc
Hello Lee Griggs!
we use cinema4d on Mac in combination with the Arnold-Renderer c4dtoa - we love it!
Especially the clip_geo is brilliant!
Unfortunately we are now facing some problems when combining the clip_geo- and the toon-shader:
Whenever the clipping_object is positioned close to a "shadow-receiving-object" (with the toon_shader applied), "tiling artifacts" occur in the shadow.  (see in the middle of the .mp4)
We have read the comments in the c4dtoa-user-guide:
  • Self-intersecting geometry or intersecting clipping objects can cause artifacts.
  • Open objects may cause unwanted clipping (should be as watertight as possible).
For this reason, we simplified the scene with „c4d-primitives“ like cubes and tried it again: the same artifacts occurred.
We already contacted Autodesk - due to the fact that Arnold is becoming part of Autodesk - but they do not seem to be that much interested in helping us.
Maybe you can help us?
We would very much appreciate your support!
Greetings,
Marcel Ruch
thiago.ize
in reply to: MarcelRuchArc
Hi Marcel,
I would suggest making a new post for this since it looks like a new problem. That will also help ensure it gets seen by folks who weren't already following this thread.
In any case, I created an internal ticket ARNOLD-12281 with your reported problem.
