Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Bug? Color Jitter not working on cloned Arnold Procedural ASS
6 REPLIES 6
simonEPZ3S
851 Views, 6 Replies
Hi All,
Using a color jitter node to make random colors on a cloned object and all works as it should until I replace the object with an Arnold Procedural/ASS object. It then shows all cloned objects with the same color.
A bug or me doing something stupid?
Using 3.0.3 and R21
Labels (3)
6 REPLIES 6
Stephen.Blair
in reply to: simonEPZ3S
You need to turn off auto instancing.
Arnold Procedural object, ASS tab
// Stephen Blair
// Arnold Renderer Support
simonEPZ3S
in reply to: Stephen.Blair
I tried that and it made no difference in either IPR or PV.
Stephen.Blair
what are you jittering? object, face, procedural, or user data?
// Stephen Blair
You have to use the Procedural settings in the color_jitter shader and turn auto instancing off on the Arnold Procedural object.
Thanks Peter/Stephen. I have now got it working. I was using the object setting and not the procedural.
I did also notice that you need to deactivate the ASS object (green tick to red cross in object manager) and then reactivate to make it work. I stumbled across this when creating a new scene and following your instructions it still did not work correctly. I then changed the ASS path to another file and it worked. Further tests revealed the ASS just needed to be deactivated and then reactivated to make the jitter work.
Seems like the IPR does not update properly after these changes and needs a restart or full re-export of the procedural.
