ACES Flat Shading Incorrect
cassidydodge2
cassidydodge2
Hi there,
I am trying to render a flat background based on a set RGB/Hex value but the colour appears much darker in the IPR and final render than what it should be.
Attached is a screengrab of the render. I've extended the background in Photoshop using my original RGB/Hex colour to demonstrate what it should look like.
Note: My background is a flat shadowmatte but even as a a flat plane it renders out just as dark.screen-shot-2022-03-14-at-35151-pm.png
cassidydodge2
Sorry, I forgot to add that I am in the default colour space, ACES.
lee_griggs
Does it happen without the shadow_matte?
Does it render like that with sRGB?
Lee Griggs
Arnold rendering specialist
AUTODESK
cassidydodge2
Hi Lee,
Yes, I have the same issue even with a flat shader in ACES.
If I switch to Legacy in the Color Manager I get very close to an actual match (see below) but I would prefer to ACES if I can.
peter.horvath6V6K3
In which color space do you have your input RGB values? Colors in Cinema 4D are in sRGB space by default (Edit > Project Settings... > Input Color Profile), therefore there's an sRGB to linear (ACEScg) transform when exported to Arnold.
cassidydodge2
Hi Peter, Yes, my input color space is sRGB. What should it be set to in order to get the correct values with Arnold and ACES?
peter.horvath6V6K3
Actually, I think what you want is changing the View Color Space to Un-tone-mapped (sRGB). The default view color space (ACES 1.0 SDR-video) has a tone mapping which makes the result darker.
I assume your display color space is Photoshop is sRGB and so is your input color.
