Snow Shader for 3ds Max
Message 1 of 9
Hi there,
I was hoping someone might have some information about creating a snow shader in 3ds Max. I have found plenty for Maya that I have tried to follow, am example being
https://www.artstation.com/artwork/J2wBz
but there are just some shader settings that I can't quite match across.
Does anyone have any links or tips about this.
Helping my daughter out with a school project and can't get past the "dad that doesn't look like snow" phase 🙂
Replies (8)
Message 2 of 9
CiroCardoso3v
There is an example here that explains the shader
http://zenopelgrims.com/project-shadersxyz.html
Lighting also plays a big part in it.
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Message 3 of 9
I am not sure how I can use that in the material editor on max though, sorry just not sure how to make the shader from that image.
Message 4 of 9
lee_griggs
This is in MtoA, but the shaders are the same in MAXtoA, so it should be easy to reproduce.
https://www.youtube.com/watch?v=s8Bq5Ou_Plc&ab_channel=ArvidSchneider
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 5 of 9
Thanks for that, the end result is really nice - I'll see if the ole brain can figure this out 🙂
Cheers
Message 6 of 9
Hmm I lost this already at the displacement shader - there isn't a node in Max like this.
Also, I assume I am building that from a standard surface as the al_shader node doesn't appear in max in any form or fashion I can see.
I got as far as the low frequency noise 🙂
Message 7 of 9
lee_griggs
Yes, standard_surface.
Displacement
Noise, image, etc
Layer texture maps using a layer_RGBA too.
Let us know how you get on.
Lee Griggs
AUTODESK
Message 8 of 9
Still bumbling away with it, but came to a halt with the mix map. I have the two noise nodes, but they don't join to the mix shader node that I need to then use as the map in the modifier stack for the arnold properties on the fluid.
I can see all the bits and pieces I need, just can't seem to join them up like they are in Maya.
Message 9 of 9
lee_griggs
try the layer_RGBA instead.
Lee Griggs
AUTODESK
