Operators - Collection
CiroCardoso3v
Advisor Advisor
Message 1 of 28
CiroCardoso3v
I want to use more Operators to control my scenes. Going to the next level, I have hope. For this particular situation, what I have is a massive scene, with trees, grass, forest pack, tons of stuff. Now what I need to do is adding some people, but I don't want to render the entire scene again.
I want to apply a shadow matte to everything except to those 3 or 4 models. In my mind it is easier to select everything and subtract those models and then apply the shadow matte.
My question is what parameter do I need to add to the Collection Operator for that to happen?
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Replies (27)
Message 21 of 28
CiroCardoso3v
The same with me. If I try to apply a Map to Material it just stops working. It looks like a bug to me. Do you need more info to report that as well?
Ciro Cardoso
Message 22 of 28
Stephen.Blair
@Ciro I was putting the wrong name in the selection. Putting the name of the Map to Material node doesn't work. You have to put the name of the node connected to the Map to Material.
Then 3ds Max was ok. I didn't crash with the Shadow Matte
// Stephen Blair
// Arnold Renderer Support
Message 23 of 28
Stephen.Blair
@Ciro
Are you using volumes or VDBs in that scene?
If so, it could be that the operators are being applied to them too
// Stephen Blair
Message 24 of 28
CiroCardoso3v
Thanks @ I will give it a go. No VDBs. The tree is an Alembic file and then the grass is a Forest Pack.
Ciro Cardoso
Message 25 of 28
Stephen.Blair
Hi @Ciro
I didn't think so (VDB), but I had to confirm. Unfortunately your CER reports have the wrong symbols and make it look like VDB was involved.
If you can still reproduce the crash, a scene would be great...you can always send it to [email protected]
// Stephen Blair
Message 26 of 28
CiroCardoso3v
Still a little bit buggy the work with ARV and Operators, at least with the Shadow Matte.
Using the ginstances to apply to the Forest Pack. Sometimes it works, others times it doesn't. Gosh I really hate Forest Pack. We need Bifrost as soon as possible.
Ciro Cardoso
Message 27 of 28
CiroCardoso3v
So, if the a Target node is active and you start ARV, doesn't apply the effect. You need to clear target and set target again.
Ciro Cardoso
Message 28 of 28
CiroCardoso3v
Ok, thanks to Stephen for the reply and help with this. A summary of the workflow
*.(@node=='polymesh' or @node=='ginstance') and not(name== '/model1' or name =='/dummy/*'))
Then to change the material and if you are using Shadow Matte, you need to assign the not the Map to Material node, but the Shadow Matte map.
shader="/shader_name"
Ciro Cardoso
