Hi Arnold users,
I'm facing quite an issue on my current projects:
In 3ds max 2020 and 2021, when rendering an image sequence using Arnold v 4.3.1.20, the fur/hair is not following the meshes deformations, it keeps its initial position. This occurs on meshes with skin, morpher, skinwrap and even simple modifiers animations like bend. Baking the deformations in a Point cache modifier won't work neither.
However, in the viewport, we can clearly see the fur following the deformation on the mesh, rendering still frames from anywhere in the animation works.
This is why I believe this issue may be more an Arnold than an Ornatrix issue . I have also declared this bug to Ornatrix developers.
Do Ornatrix+Arnold users experienced the same issue?
Here is a video showing the issue:
https://youtu.be/ySdXVUxCrhs
