.mtlx import failed
.mtlx import failed
RenderQ
.mtlx import failed
RenderQ
Hi, I am trying to import .mtlx material into the MAXtoA and I get this. What might be the problem?
Material is downloaded from this website. https://physicallybased.info/
lee_griggs
It seems to work for me. Are you using the latest plugin?
Lee Griggs
Arnold rendering specialist
AUTODESK
RenderQ
Thanks Lee for confirming that it works. That got me thinking and I found the problem. The problem is that I tried to load that file from a network drive. Not sure why that happens but when I copy the file on local drive it load properly.
RenderQ
Also when I replace the IP with a drive letter it works. So maybe the open file name dialog should return drive letter instead of a IP adress for the network drives?
