volume on top of two meshes
thomaslisle1309
Message 1 of 10
thomaslisle1309
Hi i have a volume with some displavement.  its on top of several meshes but it only treats the first one normally the others all change the colour of the volume making it go dark.   I cant work out whats going on   is there a way to fix this cheers Thomas
Replies (9)
Message 2 of 10
lee_griggs
Can you screengrab your geo/settings/shaders/renders, please? Does increasing volume_ray_depth help?
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 3 of 10
thomaslisle1309
hi Lee thanks for getting back to me   increasing  ray depth doesn't make any difference  just 1 diffuse ray renders the same as 5 on every ray depth item !    I have tried hundreds of options cant seem to get around it    I have two planes in the background and a cube right under the volume.   the volume should be bright red
many thanks kind regards
Thomas
Message 4 of 10
lee_griggs
Can you post a simple scene, please?
Lee Griggs
AUTODESK
Message 5 of 10
thomaslisle1309
ere you go mate
Message 6 of 10
lee_griggs
It looks like the way the circular ramp is being used in the volume_displacement is causing it to look like this. I would maybe use a camera_projection with the circular ramp.
Also, the HDR textures seem to be mixed up. The Sven texture is in the skydome_light.
Lee Griggs
AUTODESK
Message 7 of 10
thomaslisle1309
hi oh i see just deleting the ramp and it gets rid of the anomaly.   I will try a camera projection  UV map  later today when I have a moment.  great ! thanks
re HDR. I have only one HDR map attached to one skydome and no texture called Sven ?   could you elaborate please as I dont understand    many thanks thomas
Message 8 of 10
thomaslisle1309
heres a screen shot of the node editor skydome  I cant find a Sven anywhere
Message 9 of 10
lee_griggs
Ah, apologies. Must have been a mix up my end then.
Lee Griggs
AUTODESK
Message 10 of 10
thomaslisle1309
ok no probs   anyway all sorted   many thanks Thomas
